Inez
Hi everyone, I have not been around for awhile however have suddenly encountered a mega problem with my pixma ip 5000 that has been churning out my regular documents and an occasional pic for enclosure in the mail for family.
What has occurred is that my Easy Photo print program suddenly started giving me an Error after attempting to do a print, simply out of the blue.
My OS is XPsp2.
The error that I got was, "No support printer found. Connect a printer supported by this software. Exiting Easy Photo Print."
I called Canon and they advised me to do an Uninstall of the printer and they guided me thru the process and then checked the CP "Printers" and indeed the Printer was removed.
Then they suggested to visit the canon canada website and Install the New Drivers, new Easy Photo print and Easy Web print. I did not do this under their guidance, however felt competent enough to do this. I saved all of the d/l files on my computer desktop and then ran them.
The first time that I did the install I encountered a problem....again with the Easy Photo Print program giving the same Error as above and I did the install after the new Driver install, Easy Web Print was not an issue. And BTW, I could not find an updated Photo Record program on that site after I searched the model clicking onto Customer Support which is what Canon advised. I now only have that program on my original Install disc. Since I again encountered this problem I decided to another uninstall and do a Reg clean and see if that corrected the issue and also checked to insure that the printer was unplugged from the power bar and that I followed the install process that indicates when to install the printer in case I slipped up there.
In spite of this, the Identical problem recurred.
I did a print test page on my regular paper which is set to feed from the back and it was fine.
It is the Easy Photo Print which keeps repeating the same error. I can't print a pic and of course this is now the weekend and Canon is closed.
I am beside myself, not knowing what could be the issue. I have tried other USB ports (2.0) and that did not make a difference.
When I check the CP, the Printer is there and is ready....it is the Easy Photo Print program that even with the new version will not work and I can't understand why a regular document print will work and yet Easy Photo Print keeps saying that "No Support printer is found....as I indicated above.
Could it be that the installed drivers from my cd that were working fine until I went to print a photo are still sitting corrupted on my computer and if so how do I deal with that.
Canon said that they would disappear after the uninstall. And why I can print documents and not Easy Photo Print??
I really hope that someone has some ideas here as I am simply frustrated by this whole matter.
Something is most certainly wrong and I have the latest version of this program on my computer as I mentioned I did do a d/l from the site per Canon's suggestion, saved the files in a folder on the desktop and of course did the install of the new drivers first.
I also tried removal of the d/l updates and then did an install from my original cd that came with the printer and still the problem with Easy Photo Print existed.
I look forward to experienced users input.
Thankyou for your time...I am simply tearing my hair out now in total frustration !!!
My OS is XPsp2.
