Measuring the ColorChecker Classic with the i1Pro 2/3 Scanning Ruler
jctay
Canon Selphy CP1500
Measuring the ColorChecker Classic with the i1Pro 2/3 Scanning Ruler - Part 1
. Developing a Measurement Method for the ColorChecker Classic Using the i1Pro 2/3 Scanning Ruler
. Establish a Reference: Obtain reference measurements using Spot Measurement.
. Perform Scanning Measurements: Measure the ColorChecker Classic 24 using the i1Pro 2/3 scanning ruler.
. Determine the Compensation Factor (CF): Compare the scanning measurements against the Spot Measurement reference to calculate the required Compensation Factor
Why the Raised Paper Frame Causes Problems
The physical ColorChecker Classic 24 has a raised paper frame surrounding its recessed color patches.
When using the i1Pro 2/3 scanning ruler, the ruler rests on the raised frame rather than the actual measurement surface.
This increases the distance between the instrument's measuring head and the color patches, potentially affecting measurement accuracy.
Precautions When Taking Spot Measurements
Position the target aperture precisely over the centre of each color patch.
Press the i1Pro 2/3 straight down firmly against the positioning target when taking each reading. Ensure that the measuring surface is as close as possible to the instrument's measuring head.
Measurement Workflow
- Perform three sets of measurements using Spot Measurement.
- Perform three sets of measurements using the scanning ruler.
- Calculate the average results for both Spot Measurement and scanning ruler measurements.
- Determine the Compensation Factor (CF) by comparing the two sets of averaged results.
- Apply the calculated CF to the scanning ruler measurement results.
Method A — Calculation Method
Method B — Wavelength-dependent Compensation
Measuring the ColorChecker Classic with the i1Pro 2/3 Scanning Ruler -Part 2
Method A: Scalar CF
This method applies one constant compensation factor to every patch and every wavelength
Model complexity -Simpler, same multiplier throughout, preserved Spectral curve shape
. One factor for the whole spectrum.
. corrected = CF x measured
Method B: Wavelength CF + wavelength shift
Model complexity -36 factors, varies by wavelength, modified Spectral curve shape
. corrected(l) = CF(l) x measured(l) + S x slope(l)
. 36 factors (one per wavelength) plus ONE wavelength-shift term S.
. slope(l) is how steeply the measured spectrum rises or falls at l.
. All 37 values are fitted together by least squares.
Averaging Measurements
Create Reference Set: ColorCheck24-Spot-Avg-Reference.mxf
ColorCheck24-Spot-set1.mxf
ColorCheck24-Spot-set2.mxf
ColorCheck24-Spot-set3.mxf
Measurements using the scanning ruler, create ColorCheck24-Ruler-Avg.mxf
ColorCheck24-Ruler-set1.mxf
ColorCheck24-Ruler-set2.mxf
ColorCheck24-Ruler-set3.mxf
Scalar CF vs Wavelength CF
Before CF:
ColorCheck24-Spot-Avg-Reference.mxf vs ColorCheck24-Ruler-Avg.mxf
After Scaler CF:
ColorCheck24-Spot-Avg-Reference.mxf vs ColorCheck24-Ruler-Avg_CF-Scalar-1.012474.mxf
After Wavelength CF:
ColorCheck24-Spot-Avg-Reference.mxf vs ColorCheck24-Ruler-Avg_CF-WavelengthShift.mxf
Interpretation
The comparison revealed a maximum ΔE00 difference of just 0.08 between the two corrected methods.
This demonstrates an exceptionally close agreement in their colorimetric results, despite the use of different spectral correction approaches.
Measuring the ColorChecker Classic with the i1Pro 2/3 Scanning Ruler -Part 3
Calculate-CF v0.5
SPECTRAL COMPENSATION FACTOR CALCULATOR
Supports drag and drop
Filelists
Calculate-CF.bat
Calculate-CF-SaveOFF.bat
Calculate-CF-SaveON.bat
Calculate-CF.ps1
Supported Compensation Methods
. Scalar Compensation Factor (Scalar CF)
. Wavelength-Dependent Compensation Factor (Wavelength CF).
Supported File Formats
. mxf and .ti3.
. The .ti3 format must contain spectral measurement data, such as measurements obtained using the X-Rite i1Pro 2 or i1Pro 3.
Calculate-CF.bat
The master copy comes with preset Compensation Factors (CFs),
The CF is derived from ColorCheck24-Spot-Avg-Reference.mxf and ColorCheck24-Ruler-Avg.mxf.
Always make a copy of the master file and rename it before use. Use the copied file as your working .bat or .cmd file.
Similar to Calculate-CF.bat, but with a user-configurable SAVE_MODE=ON setting.
When both Reference and Measurement Files Are Dragged In,
The Compensation Factor (CF) is calculated from the supplied measurement data.
The calculated CF is applied to the measurement data and saved for future use.
Only One Measurement File Is Dragged In
The internally stored CF is applied to the measurement data to generate the corrected measurement data.
Recommended as the default working batch file for routine use.
Identical to Calculate-CF.bat.
User-configurable SAVE_MODE=OFF.
Both Reference and Measurement Files Are Dragged In
. The Compensation Factor (CF) is calculated from the supplied measurement data.
. The calculated CF will be applied to the measurement data but will not be saved.
. The internal stored CF will be applied to the measurement data to generate the corrected measurement data.
Example:
Drag and drop ColorCheck24-Ruler-set1.mxf onto Calculate-CF-SaveOFF.bat.
Two corrected measurement files will be generated:
1. ColorCheck24-Ruler-set1_CF-Scalar-1.012474
2. ColorCheck24-Ruler-set1_CF-WavelengthShift
Comparison with PatchTool
Left: ColorCheck24-Spot-Avg-Reference.mxf vs ColorCheck24-Ruler-set1_CF-Scalar-1.012474
Right: ColorCheck24-Spot-Avg-Reference.mxf vs ColorCheck24-Ruler-set1_CF-WavelengthShift
ZIP
Program Files
Calculate-CF.bat
Calculate-CF.ps1
Reference file
Meaurement files
ColorCheck24-Ruler-set2.ti3
Measuring the ColorChecker Classic with the i1Pro 2/3 Scanning Ruler -Part 4
Reference vs Sample — With and Without Compensation Factor (CF)
ColorCheck24-Spot-Avg-Reference_vs_ColorCheck24-Ruler-set1_spectral
ColorCheck24-Spot-Avg-Reference_vs_ColorCheck24-Ruler-set1_CF-Scalar-1.012474_spectral
ColorCheck24-Spot-Avg-Reference_vs_ColorCheck24-Ruler-set1_CF-Scalar-1.012474_spectral.png
ColorCheck24-Spot-Avg-Reference_vs_ColorCheck24-Ruler-set1_CF-WavelengthShift_spectral
ColorCheck24-Spot-Avg-Reference_vs_ColorCheck24-Ruler-set1_CF-WavelengthShift_spectral.png
jctay,
I wonder, what is the purpose of this exercise?
Josh
There isn't any particular practical objective.
I'm simply exploring different measurement methods and trying to understand how the i1Pro 2/3 behaves under different measurement conditions.
For example, I'm interested in whether measurements taken with the scanning ruler can achieve comparable accuracy and repeatability to spot measurements, and whether a compensation factor can help account for differences in measurement conditions.
Enjoy your researching.
I'd be interested in seeing the patch measurements you obtained from your ColorChecker Classic.
I've been using a ColorChecker digtal image that I print with various paper profiles to evaluate the accuracy of the paper profiles. I use an ES-2000, the OEM version of the iPro2 to measure the prints via Chromiq and compute DE2000 values.
I was curious to see what the results would be if I measured the ColorChecker Passport and a mini Color Checker Classic that I have. I was surprised that the average DE2000 values from the physical ColorCheckers were not much different than those from the printing process, all less than 2. I expected the physical ColorCheckers to be much lower. Is this because of the age of my physical versions or the variability in measurement? I don't know. Yours would provide additional data points.
Josh
