jctay
- Sep 18, 2026
- Canon Selphy CP1500
Measuring the ColorChecker Classic with the i1Pro 2/3 Scanning Ruler - Part 1
. Developing a Measurement Method for the ColorChecker Classic Using the i1Pro 2/3 Scanning Ruler
. Establish a Reference: Obtain reference measurements using Spot Measurement.
. Perform Scanning Measurements: Measure the ColorChecker Classic 24 using the i1Pro 2/3 scanning ruler.
. Determine the Compensation Factor (CF): Compare the scanning measurements against the Spot Measurement reference to calculate the required Compensation Factor
Why the Raised Paper Frame Causes Problems
The physical ColorChecker Classic 24 has a raised paper frame surrounding its recessed color patches.
When using the i1Pro 2/3 scanning ruler, the ruler rests on the raised frame rather than the actual measurement surface.
This increases the distance between the instrument's measuring head and the color patches, potentially affecting measurement accuracy.
Precautions When Taking Spot Measurements
Position the target aperture precisely over the centre of each color patch.
Press the i1Pro 2/3 straight down firmly against the positioning target when taking each reading. Ensure that the measuring surface is as close as possible to the instrument's measuring head.
Measurement Workflow
- Perform three sets of measurements using Spot Measurement.
- Perform three sets of measurements using the scanning ruler.
- Calculate the average results for both Spot Measurement and scanning ruler measurements.
- Determine the Compensation Factor (CF) by comparing the two sets of averaged results.
- Apply the calculated CF to the scanning ruler measurement results.
Method A — Calculation Method
Method B — Wavelength-dependent Compensation
