Canon Pixma Pro 100 showing feed tray cover Error 1270
theartofjas
Print Lurker
Canon Pixma Pro 100
I have an art festival in 6 days.
My Canon Pro 100 randomly showed "Error 1270" which says the feed tray cover is open. The feed slot cover was closed. I reopened and closed it and the error still persisted. It's been 2 weeks of me trying to figure this out.
I've deep cleaned as much as I can physically reach. I popped off the cover and noticed something sticky on the right side of the paper feed roller near a metal part. I cleaned it and everything moves smoothly. The error still pops up. It pops up even with the entire printer closed.
The feed slot cover appears to be laying flush with the printer. I bought the printer secondhand 6yrs ago and never had this issue.
I'm tempted to take the side panels off, but I don't know which side the feed tray sensors are.
Please help!
Maybe this instruction will help in disassembling the printer and locating the switch or sensor?
If the sensor is a switch maybe it can be opened and cleaned. See this.
Maybe a replacement switch could be found. See this.
Hi, I have the same problem with my Pro 10S. I've taken the printer apart (following the useful guide mentioned above), found the sensor which looks fine and has no obvious way to clean it. So, can I get a replacement sensor or is it a replacement printer that is needed?! I attach a photo of the sensor.
Any suggestions for finding a new sensor is welcome.
Phil
It looks like the switch is a newer version that cannot be taken apart? Compare the first image in this post. Maybe some electronics contact cleaner can be sprayed into the switch via the switch arm opening?
If you short the switch it will always signal door open and you can print. You will of course have to make sure the door is open before printing or risk a serious paper jam. But this dodgy solution is better than discarding an expensive printer because of an unrepairable and unavailable switch.
Maybe you can find a defective printer cheaply and use that as a donor? I think this type of switch is used in many Canon printers.
You could also try googling "door indicator switch for canon printer" this finds more hits like this. It also finds that the Canon parts number is QC3-4368-000 for a switch for the G1000-G2000-G3000 ink tank printers. I think this switch is used on most Canon printers.
I have a Canon TS5055 that often pauses printing due to an intermittent contact problem with the door switch. I'll try do take that printer apart and examine the switch.
