- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
The next link will explain it in English:
http://www.druckerchannel.de/artikel.php?ID=1830
You actually can combine those 2 methods and use a pan head silicon plug above the ink chamber, but filling done with the German Durchstich method. This is the combined method I'm using currently on my Pixma MP780. Then you would have the best of both worlds. Easy refilling without messy hands and availability to purge the sponge. However: during purging the liquid will escape from the refill hole too, so keep this in mind to avoid messy spills.
However: the Durchstichmethod is very reliable. There are guys already refilling their carts more than 10 times or even more without any need to purge the cartridge. There is an automatic equilibrium balance obtained with this method in the sponge chamber: there is almost no danger of oversaturating the sponge, as in the case using the traditional refill method through the ink chamber by which you have to squeeze 5-10 drops of ink after refilling to avoid banding in your printouts.
Try Hobbicolors or Inktec CLI-8 compatible ink. This is really great quality refill ink and Inktec is actually the ink recommended on the german druckerchannel.de site.
