How do you preserve your ink cartridges?
juntjoo
XP-960
I'm about to open a couple new ones but only to use for testing so I don't want them to dry up and die prematurely. Normally I just put scotch tape on the underside on I guess the "printhead" part. Should this method suffice or do you have a better suggestion?
kian mury
dremel digilab 3D20
It is very sensitive, But you can follow below mentioned:
Always Store Cartridges Upright, Look for a Cool, Dry & dark Place. Along with the cartridges, place a damp cloth or paper in the sealed tub to initiate humid conditions in a controlled environment. If cartridge nozzles are not stored in airtight and humidified conditions they can crust over or dry out anytime. Do not allow anything to touch the cartridge nozzles.
juntjoo
XP-960
Thanks! Sounds like a great idea, but I see the point in all the steps.
I know that if I put them nozzle down, they leak. Would you recommend upside down? And leave them uncovered?
Actually, most of them I drilled holes on top to refill. I think I'll tape and store as you suggest in some cheap plastic storage containers.
