Hi. Both myself and my Brother MFC J6930DW need some advice.
phild
Brother mfc j6930dw
Is it safe to use a black dye ink alongside my pigment inks ? My black pigment ink keeps clogging my print head. Many thanks. Phil
Yes it is, if you put it in the same cartridge, there are other issues you may have also like the printout won’t be highlighter proof for 1..
Are you using OEM or aftermarket ink?
How often do you print something? Daily? Every few Days / Weeks / Months?
phild
Brother mfc j6930dw
Hi. I print on a daily basis. I use csii system.( continous ink system ). My colours print great its just the black that keeps clogging up my printheads. I dont use OEM, I use inks bought from Amazon. Many thanks
Use a different aftermarket Black ink. Pigment particle size variations may cause clogging.
It could be the CISS.
Use OEM Black ink. It's formulated for the printer and probably has less risk of clogging.
