ThrillaMozilla
- Jan 18, 2011
It took me a while to get to this. The results are better than I expected.ghwellsjr said:What I would like to achieve now is to know if the seal between the [Inktec] clip/insert and the outlet port on the cartridge is air tight. ...do the air tightness test under water with a completely dry cartridge.
I don't have a transparent cartridge, but I did it by weight. I sealed the vent of a dry HP564XL magenta cartridge with two big lengths of gunky black electrical tape. Then I used an Inktec clip with a 10 mL plastic Luer-Slip syringe. The cartridge capacity, as I recall, is 10 mL. I clipped it into an Inktec filler in the usual way and immersed the assembly in water. I drew back the syringe all the way and held it for about 10 seconds or so. That should give a pretty good vacuum (about 0.5 atm). I the syringe and cartridge before and after immersion, after wiping thoroughly to remove external water.
The syringe gained 0.000 g. The cartridge gained 0.491 g. I looked, and there was no water in the internal volume of the Inktec adapter, so I would say that adapter-syringe part of it was virtually perfect. The actual performance with air instead of water might be worse, but I don't think it could be much worse.
I'm pretty sure the main leak is along the edge of the label, where it's hard to get the tape down and sealed. It's probably possible to do better, but I expect that this will usually be the main vacuum leak.
By the way, very nice results, Gigigogu! Users of opaque cartridges everywhere thank you.
Also nice!gigigogu said:Just finished 300 pages print job, without any problem (mostly black text on solid color backgrounds, plain paper, standard quality, Pixma 5000, CMY cartridges refilled with Freedom Method).
