- Sep 10, 2007
- Laramie, Wyoming
- Canon i960, Canon i9900
More that likely it is the ink. You will have to make tests with different papers, BUT, just because the paper is UV resistant, doesn't mean the combination of ink and paper is resistant. After all, the paper may not fall apart from UV exposure.
In general, dye inks are not as resistant to fading as pigment inks, but I wouldn't recommend using pigment inks in a CISS system, and only if your printer was designed for pigment inks. I don't know of it is.
Is the problem new/occurred recently? Did you change something if it is??
Are your inks from a known supplier? If, so, who?
Wayne
Wayne
