Epson ET-8550 Velvet Fine Art Paper settings uses Pigment and Dye Black
ThrillaMozilla
This is an almost desperate situation for me. I sort of gave up printing years ago because the blacks were blocked up. And now I have a new Epson ET-8550 with lot of Red River Premium Matte 11x17" double-sided for calendars (with lots and lots of pictures). Using my profile or the Red River profile, either way the blacks are blocked up and the shadows are murky.
Now I find out that Jose Rodriguez and others have the same darned problem. Keith Cooper shows a picture made with his wonderful profile that's just ghastly. Someone showed a screen shot of the graphical presentation of the profile for that paper -- I think it was the same paper -- which shows pretty badly blocked shadows. He says it's good paper, and there's nothing really wrong with the profile -- you just can't use that paper for that kind of picture -- and he prints a high-key photo to prove it! I thought a profile is supposed to take care of those problems, and there's no way I would call it a good profile if it doesn't work. I understand that one paper might not print as black as the next one, and I know something about the rendering intent (usually Perceptual) for attempting mitigate the situation. But it's still quite black. I reject the notion that the papers can't reproduce the shadows, and the profile doesn't take care of it. It seems pretty poor to me that even Keith Cooper has to resort to lots of test prints. At some point it's just trial and error.
So is Jose telling us that a profile made with a VFA paper setting gives good results, but the only paper he found that works right is not even intended for inkjet printing?! (Sorry to be a pessimist, but what a miserable situation unless you're using the same paper.)
Now I'll be happy as a clam if I can get superior results without blocking the shadows. I've calibrated the heck out of my already accurate monitor (with an X-Rite i1 Studio), and I've been through the settings check list with a pro. Proofing doesn't even work because it gives a poor representation of the print. It just shows the images as fogged. Until I can get results, I really don't know what I'm doing.
Any suggestions? Do I understand the situation correctly?
bplaman
Epson Stylus Photo 1500W
Hello.
To see if pigment ink is being used up when printing a photo print, you need to:
- turn on the printer (if it was not turned on)
- download the WicReset utility from the official website of the developer:
https://www.wic.support/download/
- run the WicReset utility
- select the printer in its menu
- press the Status button in the Control menu and write down the pigment ink percentage value
- print a photo print
- press the Status button in the Control menu again and write down the pigment ink percentage value again
IF THESE TWO VALUES ARE DIFFERENT, IT MEANS THAT PIGMENT INK IS USED UP WITH THIS TYPE OF PRINTING.
IF THESE TWO VALUES ARE THE SAME, IT MEANS THAT PIGMENT INK IS NOT USED.
thebestcpu
Epson SC P900
Hi @ThrillaMozilla
To solve you particular problem, it might have been better to start a new thread as it might get buried here.
That said, sounds very frustrating and yes with the right settings and profile you should not have that level of a problem.
Since you are likely a expert on this already and way ahead of me, please don't take my comments as too low a level (they are yet you did not give details) yet I will mention all that come to mind that can cause this problem.
- Are you on Mac or PC. If Mac, make sure you are not using their AirPrint driver as opposed to the official Epson driver.
- There is always the potential for conflict between the software controlling the printer or the printer controlling the settings from the front panel. I prefer settings from the software to insure settings stick and are easily visible.
- I know its basic yet do you have Black Point Compensation turned on
- Are you using the version 2 Profile from Red River for this paper. That profile became available in January 2025.
- What media setting are you using. Here is a link from Red River on recommendations for media settings for that paper:
https://www.redrivercatalog.com/download/32-premium-matte-double-sided-recs.pdf
- And lastly are you using perceptual rendering? Let me show you the curves in the Red River ICC profile for relative colorimetric vs perceptual. The almost flat line on relative colorimetric is concerning
Relative Colorimetric:
Perceptual
Again excuse the lack of my expertise yet I know sharing details both direction can help forum members help you better in solving your problem.
John Wheeler
ThrillaMozilla
Hello.
To see if pigment ink is being used up when printing a photo print, you need to: ...
Or, for a crude method that can be used anywhere, I would just wet the print. If ink bleeds, it's dye. Then soak it in water to check before and after appearance.
ThrillaMozilla
Hi @ThrillaMozilla
Yes, you're right, of course. There's just too, too much to write at the moment.
I'm not an expert at digital photo printing. The software is absolutely overwhelming. I gave up on making nice digital prints myself a few years ago, and I made my last silver-gelatin print in 1985.
PC. If only software settings stuck and were comprehensible.
Check, check, Perceptual, check, and check.
Perceptual
Thanks. That's really helpful, more than you can know.
I should actually caution people not to help too much until I can supply much more detail in another thread, as you suggested.
bplaman
Total madness. Why ruin a print when you can do it in a couple of seconds using WicReset. Claria HD ink does not dissolve in water after drying.
Epatcola
various
Madness - lol.
I loathe installing software and cluttering my system without good reason especially software from a dodgy looking source. I did try it and blew it away with the equivalent of a restore point having no further use for it. That took way longer than a couple of seconds.
The ink remaining display reads in 1% units. 1% of a 70ml tank is enough for 1/2 sq foot of print and it would have to be pure black (a useless print) and the theory is the printer mixes dye and pigment black in unknown proportions. You would have to print several black sheets to know pigment ink is not being used.
So your idea is a PIA installing crappy software, takes way longer than a few seconds and wastes a lot of ink and paper.
Wetting the paper and seeing if it runs only tells you it is using some dye ink.
Printing on glossy photo paper some of the the Epson pigment black sits on the surface and can be rubbed off which tells you it is using some pigment ink. I don't know why that happens. Perhaps Epson pigment inks for document printing have larger particles than their pigment inks for photo printing.
If you have a spectrophotometer then readings from a black patch will tell you if it is using some pigment ink.
Epatcola
various
You are a liar.
The WicReset program does not need to be INSTALLED, since it consists of one executable file. It just needs to be downloaded to any folder and launched with one click of the mouse. Your letter does not make me laugh.
wicreset.exe from the link you posted:
"before continuing with the installation"
wicreset.exe isn't signed. A google search for "Superprinter LLC" returns a single hit which is a Malware analysis of weireset.exe with the conclusion of "Suspicious".
Via the two obscure payment processors they use (2manuals.com and payproglobal.com) is the only way you might be able to find out who or where the producer of this software is,
There is probably nothing wrong with it. however, it is certainly not the kind of software I want to install or run without very good reason.
ThrillaMozilla
Hi @ThrillaMozilla
Perceptual
John Wheeler
I think I owe everyone a follow-up.
I contacted a Red River technical support person, and she was very helpful. A single shadow adjustment in Gimp ameliorates the problem, and as a bonus, it's a local contrast adjustment that I didn't know about. I'm now using the Velvet Fine Art paper setting (with my own profile) that Jose Rodriguez and Keith Cooper mentioned. The Red River profile and recommended settings seem to work as well or almost as well.
Nevertheless, I don't think the BPC and perceptual rendering systems are working quite right. Matte paper offers pretty good blacks (beautiful, actually), with a reflectivity reportedly around 2%. I have the pictures to show that matte paper can reproduce the pictures I want. The problem is that I have to make large manual brightness corrections. The profiling and printing software seems to handle this automatically for glossy paper, but it works poorly with some matte paper, and it doesn't even use all the range of black tones.
I made some measurements on my own images, and I see that there has been a lot of other discussion about this that agrees with what I found. I have a hard time understanding why the monitor does not give a good representation of the print appearance, because I have the prints to prove that it can.
I'm not sure where the problem is, but there is some interesting discussion on ArgyllCMS that may be helpful if I can get that together. Here are this and some relevant references:
https://torger.se/anders/photography/argyll-print.html
https://www.printerknowledge.com/th...ion-gives-composite-black-when-checked.15740/
https://www.printerknowledge.com/th...i-to-produce-excellent-printer-profiles.6878/
https://www.printerknowledge.com/th...acking-dark-tones-compared-to-ccstudio.16373/
EDIT: I'm considering using Relative Colorimetric rendering with no BPC, so it is at least reproducible.
