Canon Pro-1 - Reviving for a good home
gavinmckenzie
Canon Pro-1
I've read lots of threads here about the Pro-1, and I'm hoping for some guidance.
I have an original lightly-used Pro-1 which, like many, sat unused for the last couple of years. Though it was semi-regularly powered up, it hasn't printed anything in a couple of years.
It's a beast of course, and I love it, but I don't have room for it in my Toronto condo. It's cosmetically in perfect condition, as it's always had a custom dust cover on it.
I was hoping to revive it enough to resell it, or give it away to a good home, but after a few regular cleaning cycles I am left with a few persistent issues on the nozzle check pattern.
1. The PBK pattern is a little short, but given that the others in the same group aren't printing short, I'm hopeful that indicates it's just a cleaning issue and not an electrical issue.
2. The yellow pattern isn't printing at all. Does this indicate a clog in the supply line?
I've run two regular clean cycles, followed by a deep clean a few hours later.
I don't know if more cleaning cycles will help to revive the yellow, but at some point soon I'm going to run out of ink.
So, my questions:
- I'd love any advice on how to interpret the nozzle check results. I'll attach a photo of the printout.
- If there's anyone in Toronto could give this printer a good home, I'm willing to consider that rather than have it go to an electronics recycler / landfill.
There is only one interpretation I can give and it’s not good, The PBK is showing signs of electrical failure and that in itself is fatal, while the yellow is missing completely, and with a bit work it may come back, but because of the PBK’s current condition it’s pointless.
The only way this printer can work again properly is with a new print head, plus a complete set of new carts, so your printer has become a liability, and even a good home is now doubtful, and a door stop or landfill is now its only option, Sorry…
This action alone was what done the damage, because without actual printing it was worthless to power on the printer, and a bit of advice for others, don’t leave the Pro 1 turned on 24/7 that too can also be fatal..
gavinmckenzie
Canon Pro-1
Thank you for the reply. This saves me the trouble of trying to further revive or give away the printer.
The advice I received when I purchased the printer was to power it on regularly as a way to prevent clogs etc. Unfortunately it seems this advice was harmful.
Don’t worry about it, most who bought the Pro 1 have also been given the wrong advice, because it seldom clogs and is unlike any other Canon printer that needs special handling.. A Pro 10 or Prograf 300 would make a good replacement..
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
Sad for your PRO-1, but you are not alone.
Most printer gurus and also the Canon rep advise to keep a printer powered on. Why ?
I always power off my printer when finished (as I do with all electric appliances) and almost never had a clog even after a month or more inactivity. In this case it went away after one cleaning instruction.
The printheads of my PRO-9500's died from old age (and some bad 3th party ink), until now no issues with both the 9500II and the PRO-10 after almost 2 years.
