- Thread starter
- #11
Paul Verizzo
- Apr 16, 2011
- Sarasota, FL, USA
- Canon ip4500, 9000 MK II, PRO-
Get acid test pen and see for yourself if you don't believe me see for what you pay your money, test the premium paper including Pro platinum you will be amazed I'm sure.
The problem with acid paper or paper coating is for DYE inks more severe, not pigment ones but paper will yellow more rapidly if acid paper or the surface that you print on is used too.
So worrying about color management is considered without sense if you don't care on what you print.
There is no ink to paper contact except on the cheapest papers. These are what the paper trade calls "coated," usually an ultra-fine clay which allows much finer detail. These paper types are everything from card stock to brochure types of papers.
"Real" photo papers usually have the paper between two layers of PE, like the Platinum: http://www.usa.canon.com/app/html/PT101_techguide/PT101_HTML/02structure_amr.html
This has been the norm for the wet darkroom since the 1970's on the RC (resin coated) papers, and on all color papers since then. Never do the dyes or halides touch the paper.
