- Jan 18, 2010
- Residing in Wicklow Ireland
The 6700 is indeed the low battery warning, as you have already located the battery compartment, but before removing the batter, you must power the printer off with the on /off switch, leaving the power plug still in the wall, only then can you safely remove the battery.
Once you have done that the printer should clear the 6700 errors, but if it doesn’t you will have to enter Service Mode again to reset the time/date once more, normally when you get the 006 errors in Service Tool, it means you haven’t carry out, or the procedure has failed to initiate..
