Printer Profile Validation: M1 vs. M2 and ΔE2000 Evaluation
Issue1: The command boxes begin to appear before the next working screen is displayed
After the ICC profile is built:
Click Create Chart.
Change the Run Type to Verification.
Observe the attached video.
Issue 2: Fixed Seed Is Not Saved in Preset
Preset files are stored in the following directory:
\Users\UserName\AppData\Roaming\ChromIQ\presets
Example file: 1Pro-4x6in-192p-2pages.json
Currently, the preset file contains the following values:
"randomize": true,
"seed": null,
"seed_fixed": null
Expected behavior:
If the user defines a seed value (e.g., 1234), the preset file should save that value in the seed field:
"randomize": true,
"seed": 1234,
"seed_fixed": null
The user-defined seed value should be saved correctly in the preset file and retained when the preset is loaded again.
.../2 zips are attached
That's really strange. I will see what I can do about it
Edit:
Edit 2:
Fixed:
https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.7
Click Create Chart.
Nice catch :) We have not seen anything like that before, so it is good that some more people, like you, help out with reporting bugs :)
Thanks.
ChromIQ Profile Verification – Part 1: General Checks
Sharing a few screenshots showing the initial measurements and builds, without any profile refinement.
Profile Quality Check
Patch Distribution - Verify Target
Patch Distribution (RGB) - Verify target vs Profile under test
Soft Proof Using the Built-in ChromIQ Test Image
For illustrative purposes only. Actual colors may vary from those shown in the screen capture.
ChromIQ Profile Verification – Part 2: Measurement Validation
Full colour check Judged against Quick check
Grey and tone check Judged against Quick check
Colour summary (one page) Judged against ISO 12647-8 2021 values
Validation print check (ISO 12647-8) Judged against Custom ISO 12647-7
Others: Please refer to the attached document.
Hi @jctay ,
Thanks for your feedback and showing us your results....
I have a few comments from what I can see...
The "Contract proof check (ISO 12647-7)" and "Validation print check (ISO 12647-8)" report you posted have a red text warning:
the profile has been rebuilt since this sheet was printed, so these figures describean older profile than the one now in the run
This means you have created a new profile at some point, but did not re-create the colors of the verification chart, and then print that and then re-measure. Thus, it seems (if I interpret correctly), that the measurements you did measure are describing the old profile, not the new one. You should check what you did exactly, and preferibly re-create the verification chart in "From Profile's Gamut" mode, then print and measure again.
Then, the reports contain both "Within gamut" and "Beyond it" columns, which means that you did not use colors on your verification chart that were only within gamut, using "From Profile's Gamut" mode. (you have to remember to click on Generate Chart after clicking on "From Profile's Gamut" mode in Create Chart). Thus, you printed and measured a chart that was the original patch set you had for your 192 patch chart. The
This image you posted with the distribution of the colors for the 192 patch verification chart proves also that the patch distribution is not evenly distributed, which is how it looks like when the normal patch set is viewed through the profile. If you had used "From Profile's Gamut" mode it would be much more even. Though, for some reason, this view does not show the out-of-gamut patches.
Also, the distribution comparison image you shared, shown again below, shows a patch set of the 572 patch profiling chart that is not the best. There are no near-neutral gray rings for better neutral. I suggest you use one of the 600 patch presets supplied in ChromIQ instead, shown below:
Distribution of 600 patch preset for 10x15cm / 4x6" photo card. This is a better chart for profiling than the 572 patch chart you used.
Note also that the Evenness check matrices
- Maximum ΔE00, between two of the nine sheet areas (within gamut)
- Maximum ΔE00, one sheet area against the whole sheet
They require a minimum of 9 x 9 grid of patches on the verification chart, thus it could not be judged for the 192 patch chart you used.
If you wonder which chart can be used, among all saved presets (custom made or built-in) you can click on button "Which presets can be used for verification" under the Create Chart tab, while Run type = Verification.
Questions about the reporting feature:
What is your impression about the reports? Does it supply you with the information you need for quality assurance?
Comments? Impressions?
Cheers,
Knut
Hi @jctay ,
Cheers,
Knut
Thanks for your comments. 🍻
I recreated a profile using ChromIQ’s built-in 600-patch set, and the profile creation process went smoothly.
However, during verification, I spent considerably more time than expected taking measurements because the i1Pro repeatedly failed to read certain strips.
**My personal perspective**
Users who need verification features to meet certification requirements as part of their organizational processes may find these functions valuable. While I find them impressive, I believe new users will need some time to become familiar with the workflow.
For my part, I’m simply looking to improve color reproduction on an affordable photo printer for home use while enjoying the process of experimenting with printer profile creation. Certification requirements, on the other hand, are entirely new territory for me.
The most discouraging aspect has been the measurement process, which has taken up far more time than I anticipated. I’ve followed most of the precautions discussed in this forum to minimize measurement-related issues. In fact, I’m quite comfortable with the measurement workflow in i1Profiler.
I’m not sure whether other users have encountered similar difficulties when measuring with ChromIQ. I’m running it on a PC that’s more than 10 years old, so I wonder whether the CPU’s processing speed could be a contributing factor. Alternatively, could the timing or responsiveness of certain program scripts affect data transfer from the instrument and cause some strips to fail to read?
I’d be interested to hear about other users’ experiences, particularly those using an i1Pro on older hardware. :)
Thanks for doing all this testing!
Although I doubt your assumption about this being related to the measurement part of ChromIQ I will let AI check it once it is idle again.
The measurement engine is based on the code from Argylls chartread. We copied („forked“ it as it is called) to build some features into it that the regular version does not support. For example the ability to save the measurements after every strip instead of only after you have read the whole chart. This then enables the ability to show the measured vs expected overlay on top of the patches you have measured.
So in theory this should not affect the transfer from the device to the computer. But since I have noticed similar issues myself on some occasions and I have learned to never trust your instincts in this coding process I‘d rather let this get checked. Might take a while though as I am not that available this week.
ChromIQ-Windows-x64_v4.3.8-beta.1
Experiencing a Smoother Workflow:
. Import the .ti3 file and rebuild the profile.
. Set the Run Type to Verification.
. Navigate to Measure and start the measurement process.
The verification chart consists of four pages. The first page was processed successfully, but measurement failures* began on the second page and continued thereafter.
*Failures: After several unsuccessful attempts to read a strip, skip to the next strip.
This beta does not contain any fixes related to the issue you have and the next one probably won’t either as Claude was / is working on other things that I had on my to-do list. Your report follows after this. However as I mentioned this might take a while because I feel this needs a closer look.
ChromIQ: i1Pro Test Button Integration for Measurement Retry
Current Behaviour:
When a measurement error occurs and a rescan is required, the user must click the Retry button on the screen to resume the measurement process.
Suggestion:
Allow the user to operate the i1Pro's physical Test Button to handle the retry process:
. Press the i1Pro Test Button once to select Retry.
. Press the Test Button a second time to proceed with the rescan.
This would simplify the workflow and reduce the need to interact with the on-screen controls during measurement.
The idea was inspired by i1Profiler.
