i1Profiler miniature + small RGB printer targets: 10x15 cm, 13x18 cm, A5
Thanks to @Ink stained Fingers idea using a very small target (96 patches) on a small 10x15 cm (4x6") paper to obtain a rudimentary but still a satisfactory RGB printer proifle, I took the chance to optimize the amount size (increase to the maximum amount that can be printed on small photo cards ranging van 10x15 cm to A5 (210x148.5 mm) with patch sizes from 192 to 450 patches.
The idea was based on the rather small patch size the Spyderprint uses with its High Quality target containing only 225 patches, that was based on a RGB-grid of 5x5x5 and with additional patches (mostly around the visually most important area around the neutral axis) up to 225 patches) and can still produce very good printer profiles:
By using the same idea: based on the RGB cube of 5x5x5 for 10x15 cm, 6x6x6 for 13x18 cm and 7x7x7 for A5 and enhancing it with extra grey steps (important for good B&W printing with a smooth gradient) and a regularly distributed patch set around the neutral axis to optimize sampling rate (limited by the chosen amount of total patches) of the visually important area of the RGB colour cube, I could generate 3 sets of miniature/small RGB printer targets that, despite the small patch count, can surprisingly create very good printer profles, confirmed by the expertise of @Ink stained Fingers .
The 10x15 cm (4x6 inch) target with 192 patches (can be used for both manual scanning as well as the i1iO2 robot):
The 13x18 cm (5x7 inch) 285 patch target:
The A5 (210x148,5 mm or half size A4) 450 patch target:
The A4 (210x148,5 mm or half sizeA4) 450 target with i1iO layout (can be used too for manual scanning):
The target sets consists of 3 files of which the .txf and (and eventually the target file in tiff-format .tif, but not necessary because this is the file you want to print) is to be placed into:
\ProgramData\X-Rite\i1Profiler\ColorSpaceRGB\TestCharts
And the workfile file *.pwxf file into:
\ProgramData\X-Rite\i1Profiler\ColorSpaceRGB\PrinterProfileWorkflows
In i1profiler check the "advanced" user mode and on the left of the windows: printer > RGB printer: profiling and go to "saved workflows"and choose the corresponding *.pwxf workflow to start your profiling job after you have printed your target on the corresponding paper size and have it dried properly (at least 1 hour for pigment ink, 24 hours for dye ink).
  • Chart 285 Patches for 13x18 cm.zip
  • Chart 450 Patches i1iO for A5.zip
  • Chart 450 Patches for A5.zip
  • Chart 192 Patches 10x15 cm.zip
  • Chart 192 Patches 10x15 cm i1iO2.zip
Here is another target I have made based on the TC2.83 target that is originally included in the Gretag Macbeth iMatch software alongside with the famous TC9.18 target (and which can still be found in the i1Profiler software package). It is a small target that has initially alot of white patches in the target up to 294 patches. By removing those redundant white patches and adding 2 extra near neutral patches up to 285 patches I could make a target that fits on a small 13x18 cm photo card and also on a half size A4 paper aka A5 (210x148.5mm). Not sure what will give better profiles: this slightly modified TC2.83 target or my 285 patch target with extra grey and near neutral patches. Maybe @Ink stained Fingers can give it a try and report back:
There are 2 sets: one for manual scanning and the other for the i1iO2 robot. The manual scanning set also has a modified target for a smaller 13x18 cm photo card, with extra separation bars between the patches.
  • TC2.85 RGB.zip
  • TC2.85 RGB i1iO2.zip
So actually the TC 2.83 target has no extra benefit compared to the other targets if I have understood it.
I'm reaching the limits of data accuracy and validity with the current setup; let me just show you what is happening;
I printed the 0192 patchsheet, created a profile from it , reprinted the 0192 patchsheet with this profile and scanned it twice - directly one after the other and let i1Profiler extract the differences between these 2 scans, the average of all DeltaE's is 0.17 with a max of 0.71 . When you now add just a few more patches a possible delta of improvement will just be covered up by the scan variations. A .pdf file of all the deltas is attached.
Better data accuracy would need a tighter look to the scanning data, are the variations caused by the scanning process, would multiple scans improve the results, are the patch prints uniform enough. The i1io scan table can run in patch by patch mode - very slowly - and would even allow multiple scans per patch, but a scan may not take some minutes but hours.
Or an instrument like the Myiro9 would deliver more accurate results - I don't know.
https://www.myiro.com/myiro-9
There is something else visible from the data of the gray columns on the right side that i1Profiler does not create neutral grays along the gray axis but gives the spots along the gray axis - a=b=0 - a cool touch with some negative b-value. This was already discussed and reported longer time ago - ArgyllCMS values along the gray axis compared with a i1Profiler created profile - here in this table
https://www.printerknowledge.com/th...arison-argyllcms-i1profiler.15717/post-137159
When I browse around for 'Gray axis' and similar I find comments that neutral grays - technically neutral with a=b=0 tend to have a slightly brownish look, and the preference of people would rather be a slightly cooler tone interpreted as neutral which explains the negative b-values and that some profiling software supports that trend.
I cannot really comment on that , I haven't looked in detail into B/W printing and its complications, and this goes beyond the subject of this thread.
  • ET-8550 0192 BW-Test.pdf
crenedecotret
Hello.. Sorry to resurrect this old thread.. I was wondering if one of you had a decent target for the original i1pro rev d for 4x6 paper that would fit on maybe 4 or 5 sheets?
It could help out those of us with efi es1000 devices or old gretag macbeth spectros that need slightly bigger patches than the i1pro2
Right now I just pull out the Colormunki photo for 4x6 papers.
Hi @crenedecotret, I can make you an i1Pro1 target for you for several pages of 4x6" photo cards.
Here you are. I have used ArgyllCMS to generate the patches as it distributes the measurement points more evenly in the RGB 3D color space than the rigid i1Profiler "smart patch generator" and I also have injected 64 grey steps into the target for superior grey separation. The standard "smart patch generator"of i1Profiler only generates 15 grey steps when you choose 572 patch targets (4x143 patches on each sheet of 10x15 cm photo card).
Put the pxwf-file into the following directory:
Print each of the 4 targets on 4x6"/10x15 cm photo cards using the following print setting: borderless setting, NO expansion (retain size) (color management: off and write down the used media setting and resolution you are going to print these targets, for example: Epson Premium Glossy, quality: standard). This will guarantee the target is stretched maximally over the available paper surface without falling down over the paper surface.
  • ArgyllCMS 572-patch target + 64 greys 10x15cm.zip
crenedecotret
Thank you! Much appreciated! The borderless trick is pretty interesting. Looking at the images in i1profiler
It looks like it will work, except for maybe two things I need to sort out. First, qimage is reporting a strange paper size when I switch to borderless/retain size (6.152 x 4.2 inches). I'll probably just try printing out in Adobe color print utility to see what happens.
The other potential issue is that with a 9x9 mm patch size, the original i1pro would need to scan the patches one at a time instead of scanning rows. It will work but it wont be fun reading the patches lol
Looking at your PWXF file and the images, am I right in assuming that you are using a 120 x 170mm setting in i1profiler and then simply cropping out the larger profile name on the i1profiler generated tiffs, then replacing the "i1profiler test chart" and copyright lines with blank space?
If so, I might be able to use a combination of my "pkpatches" tool and your method to get something decent where i'd still be able to scan full rows
yes indeed: some PS manipulation involved. I have done this with my custom made ruler for the vintage i1Pro1 and it works, actually even with 8 mm wide patches it is ok to do strip reading (do it slowly).
I always use PS to manipulate the i1Profiler generated tif targets to squeeze and fit them into a given size and position on a given paper surface (use setting: hard borders when resizing the targets in order NOT to generate extra intermediate colors in the target, as you want precise defined colors on each color patch).
Just give it a try: it should work with slow reading a row.
NOTE: YOU SHOULD PRINT the modified tif-files included with the zip files, as they are defined as 10x15 cm at 360 dpi resolution and NOT the files that the i1Profiler is generating using the pwxf-file loaded (that gives 120x170 mm targets).
