- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
I have a 4K screen and this is the result of updating to this latest version:
It is not possible to assign blame based on what info you have given so far. It could be X-rite, but it also could be from your end, as the responses here and on DPReview to your inquiry demonstrate the software has worked fine for others.
Operating Sytsem version?
Is the OS up to date?
Are you using the correct bit version of the Colormunki software for your OS? (32 versus 64 bit software)
Video card make and model?
Is the video card driver up to date?
Monitor make and model?
Is the driver for the monitor up to date?
It is possible that something happened during the installation and that an uninstall, reboot and re-installation might resolve.
Check your "Display Scaling" settings, or Google for it. No doubt you have some non-standard setting that the software doesn't like. AutoCAD had an issue too where user's had to reset to their recommended display settings as some went to wide screens and text was overlapping and it wasn't working well for them.
