Does ink freeze ?
Tigerman
Jordan
Canon MG5640, iX6840
I think it is question all get in mind, but need more clear to work with printers?
If any can know when ink get freezes or not functioning properly with printers let me know ??!!
Where are you storing your inks ? Glykoles as a part of the overall ink mix are used as antifreeze in cars and are dropping the freezing point of water significantly, I think you are safe with your inks under 'normal' cold conditions.
We don't know the amount of glycol used in the inks, so we don't know the freezing point of the ink. But I think the important question is :"Will frozen ink be OK after having been allowed to slowly thaw at room temperature?"
I think no tests have been made, but the subject of frozen ink has been discussed before. see this thread and this thread.
Googling this topic...
For example, Hitachi's JP-E78 printer ink contains acetone, ethanol and propylene glycol mixed with water. That particular mixture freezes at about negative 130 degrees C, which is about negative 200 degrees F. Loveshaw's jet printer ink contains DPM Glycol Ether and Versene, and freezes at negative 143 degrees F. Most ink MSDSs state that the melting/freezing point is "not applicable," meaning that it is below 32 degrees F. Given that the composition of the inks is roughly similar, it's reasonable to conclude that printer ink will freeze, but not until temperatures fall well below the freezing point of water.
http://smallbusiness.chron.com/printer-ink-freeze-58638.html
The article suggests that water-based dye inks would survive freezing but pigment based inks would not due to aggregation of pigment particles.
Additionally, the water of the ink in the channels of the print head would expand when frozen and potentially destroy the print head. Same potential for the plastic ink cartridge.
This is good news for forum members who live in Yakutsk!
JP-E78 uses a solvent ink - with acetone etc, that's not the type of printer I'm using with aqeous ink - dye or pigment , I don't want a separate ventilated printing area for the VOC's - volatile organic compounds
Tigerman
Jordan
Well in my case I am asking about not inks stored for long time in cold temperature conditions, just the beginning of the day in early morning when start on power of printer and room temperature lets say below 7 C then this make problem to prints result.
At first I got good page (first print) -BTW how many prints can done from print head alone- due to some inks still inside print head then after I get bad starvation of inks feeds from cartridge to print head?? Is it factor of flow inks and may be get differ viscosity of inks in cold weather ?? or printer parts ? after make clean print head I got perfect result then after two hours or many prints everything seem very well.!!
you may start in the morning with a nozzle check to see what the status is, and doing a cleaning upfront, there is not really much ink in the printhead itself, and even that would not flow if it is blocked on its way from the cartridge. It may not be the ink itself but some contamination of the cleaning unit, in the pad which is pressed against the nozzle plate in the idle position. Are you using original cartridges or other 3rd party cartridges or doing refill ?
Tigerman
Jordan
I use refillable cartridge from China ? I think nozzle check will give me also perfect result !!
