- Jan 18, 2010
- Residing in Wicklow Ireland
On all the Canon models as far back as I can remember, these printers would only use photo black in combination with the other colours to print on all Matte and photo papers, even using greyscale.
On the other hand when the pigment black on your printer got clogged and died and wouldn’t print it was always nice to know that you could switch the Media setting to Matte paper and your printer was still in business, that said.
It shouldn’t make any difference at all for keen artists or Photographers a like, if they do not intend to use OEM inks in their machines, because this workaround is just as simple to amend, back and forth.
It’s only a matter of having a spare BK cartridge filled with MK ink and then you can achieve the blacker tones you were missing out on previously using the BK black, yes you will have to make new profiles, but you were going to have to do that anyway.
This workaround will require a bit more effort if you intend only using OEM inks, because you’d be forced to re-profile all you special and OEM papers again, it still can be done by simply swapping the chip on a spare OEM cartridge..
