- Thread starter
- #21
Antennina
- Jul 21, 2014
- United Kingdom
- Canon PIXMA ix6850, Epson 1400
Just thought I'd post a quick update (plus another conundrum, more to that later)...
@pharmacist - thanks, have taken your advice & ordered the inktec inks from Octoink & they arrived quickly. Am quite happy with the results, good colours using just the standard printer settings (haven't got the tool to create custom profiles). Got the photo black rather than matte and on the cheap glossy paper that I used for testing (poundland's Polaroid paper & Tesco own brand) I do see distinct gloss differential, and printing on matte (on canvas for example) the black does come out weaker than for example the dye ink prints I made. Overall I am quite happy though, so many thanks for your suggestion!
Now the conundrum I was talking about... I had mentioned in my previous posts about having issues with random blotches on printing (I was using refillable cartridges), mostly when printing on paper-backed fabric where I get it most of the time, but I did get it on paper as well (I make a couple good prints, then I continously get ink blotches) . Initially I thought that I got the wrong ink or the print head may be faulty, but then switching to some cheap non refillable non oem dye cartridges I found I got perfect prints even on fabric. However switching to the refillable cartridges I kept on getting blotchy prints, be it using dye or pigment. I wanted to try pigment inks others had success with, so went with inktec, but using refillable cartridges I again got blotchy prints & got disheartened. I do however also have a ciss system that came with the printer but contained sublimation inks, so I had not used it. On a whim, I decanted the sub inks, cleaned & flushed the system with distilled water (now that's a job and a half!!) and refilled it with the pigment inks, and lo and behold... I get perfect prints, even on fabric now!! So I assume that my problem lies with the refillable cartridges - I searched around to see if there is anything I'm doing wrong with refilling, & made sure I did not overfill them, so tried 3/4 & 1/2 full, doing a few cleaning cycles on install & then do a few full coverage colour prints (also I make sure that the airflow plug is removed when printing & I let the cartridges settle for a while before installing) . I may get a couple of good prints on paper and then blotches & I have never so far had a clean print on fabric using refillable cartridges.
Have uploaded some of the blotchy prints in case any of you may have an idea as to what I'm doing wrong or if the problem really is the cartridges. Thanks in advance for any suggestions.
