My PRO-100 came with FW 1.02 out of the box. There have been others reporting different FW numbers, such as 1.03 and 1.04 which makes no sense as those two other numbers are not even for the PRO-100.
If you look back at my post #18 where I quote CAnon directly, the Pro-10 firmware v.1.03 is supposed to fix the ink level monitoring and the firmware fix for the Pro-100 is v.1.02. I'll leave the subsequent firmware upgrade version numbers to you guys as any firmware version v.1.02 and higher should work. I did initially mistake the most current firmware version as v.1.20 due to the file name of the executable file "
fuu_-win-pro_100-1_2-ea7.exe" on the Canon web site. However, the most current firmware version I see is v.1.100
The only difference between Roy' s situation and mine, is he disabled ink monitoring and I did not. I get the correct ink monitoring behavior and he does not.
I am running 1.02 and he has updated to 1.1 I believe and there is not change. So how do we explain that? I still think there might something to having disabled the ink monitoring.
I do not discount this at all but it is lower on my list.
1) Where are other reports of this phenomena? Surely Roy is not the only one to reset a "DIM'ed" cartridge.
2) Why would Canon go to the expense of allowing a reset that functions in the critical mission of showing a reset to begin with as well as allowing a proper "empty" or "low" but nothing in between? Wouldn't it make more sense to a ROM chip instead of an EPROM/EEPROM resetable chip. Using just ROM would bypass the aftermarket resetting crowd that includes us as well as the big boy after market ink cartridge sellers. It does not make sense that Canon would go half-assed on this, especially when it probably costs a slight amount more to produce EPROM/EEPROM chip rather than ROM chips.
Until more data is available, or some finds reports similar to Roy's, I doubt DIM is the issue. As I've written before, other possibilities include, but not limited to:
1) Bad chips. Unlikely as multiple colors involved. If they are all of the same batch number than this possibility is increased.
2) Flaw in the resetter.
3) Bad reseting technique.
4) Bad firmware flash upgrade.
5) Bad printer.
Are you willing to print until empty and then DIM your cartridge to hasten the research?
