- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
To me there still looks to be a problem with magenta. Regular magenta seems OK in strength but with some clogged nozzles. The medium strength magenta seems too weak and the light magenta is almost missing. I know that different scanners see colours differently and some adjustment of settings is often needed to get a good scan of a nozzle check. But note the green tint of the "CCCMMMYBK" lettering that ought to be various shades of neutral grey.
Here is a nozzle check showing a magenta ink flow problem and green discolouration of the lettering. It was made when troubleshooting this problem: http://www.printerknowledge.com/threads/canon-mp540-strange-magenta-inkflow-problem.6904/ , click to enlarge:
Both a cartridge problem and a print head problem could cause the intermittent error. To rule out a cartridge error I, like The Hat and stratman, strongly suggest trying a new OEM magenta cartridge, to reduce number of variables. Compatible cartridges may or may not work perfectly, so they are not ideal for troubleshooting.
I think a clog in the fine channels in the upper part of the print head, from the ink inlet to the nozzles, could also cause the error. I also think that worn rubber gaskets at the ink inlets could cause such an error, so you could try interchanging the rubber gaskets from magenta and for instance photo black or yellow to see if the error now affects black or yellow. Do the cartridges click firmly in place or are they a loose wobbly fit?
