After resolving the measurement issue with Strip 36 and rescanning several other strips with misread patches, selected excerpts from the measurement records are presented below.
Very nice :) Thanks for the reporting, it helps a lot to find and fix bugs...
Things are improving, but I think there is two more bugs hidden in the resulting reports you show us...
Thus this is input for @itsab1989 and claude.
1. Grey balance is failing:
The 572 patch chart you are using has a single line of neutral grays, but after you fill the chart with "within-gamut-colour" using the "From Profile's Gamut" feature, that feature does not place enough grey patches along this line of neutral greys. I think this was possible a result of the work we did to distribute patches more evenly, but should be checked that the same amount of greys that are present in the chart from before is placed when using the "From Profile's Gamut" feature. This should be analysed.
The 572 patch chart is found here if analysis of the patch set is required:
ArgyllCMS 576-patch target + 64 greys
2. Evenness check requirements not fulfilled:
The report note says that the chart used only covers 55.7% of the page (and 60% is the required limit), which looks strange when looking at one page from the 572 patch chart:
If one adds all the margin areas, it might be true that this becomes mathematically 44.3% of the page... But that calculation does not consider that the patch area is spread out to cover most of the page and the margins are around the patch area. The minimum limit of 60% of the page area calculation, and the method used, needs to be re-evaluated so that the calculation takes into account that the patch area is spread evenly out on most of the page, and not purely looking at a mathematical area calculation, since the margins summed up give a false impression of the whole page coverage of the patch area. Dropping the limit to 50% is of course also an alternative, but this method, as I mention, is a bit misleading to represent coverage of the patch area across the page.
The chart also fulfils the other requirement for the evenness checks to be calculated, which a minimum of 9 by 9 columns and rows. This metric should work on this kind of chart.
Cheers,
Knut
I have added this to the to do list. Computer is running 9 hours straight till this point so I hope with this added 3 hours are enough for it to release the update…
Printer Profile CP1500-600.icm (600-Patch Set)
1. Patch Distribution Verification Patches vs. Profiling Target Patches
Patch Distribution Verification Patches vs. Profiling Target Patches 600patch.png
2. Grey and tone check · Judged against Quick check
3. Full colour check · Judged against Quick check
Nice... you got better results with this chart I think
The reports
"Contract proof check (ISO 12647-7) · Judged against ISO 12647-72016 values" and
"Validation print check (ISO 12647-8) · Judged against ISO 12647-82021 values"
are telling of great quality I think :)
I notice you are creating separate projects for the 572 and 600 patch measurements. That is fine, but I hope you know you can create new runs (run 1, run 2, run 3 etc) and have all the different profiling attempts within the same projects, for example by separating the runs by paper type, or just by the different charts you use... You can use the run description field to differentiate the various runs...
Another tip:
If you would like to compare the measurement report from one run agains another run, or, in your case, a run in one project against a run in another project, then you can do this by adding the measurement you want to compare from the other project. Click the "Add Profile's Measurement" and navigate to the ti3 file on the other project (under the verifications folder, and the dated folder for the verification measurement).
The measurements from the other project will then appear:
You can then select which measurements to include in the report and then you will see the results side-by-side, and if the 572 patch chart was better or worse than the 600 patch chart :)
Would be interesting to see ...
In my example above, I chose two different printers, but preferably they should be the same :)
And a question:
With all the measuring you have now done... Are you satisfied with the results and what you see?
Cheers,
Knut
Hi @jctay ,
If you try the latest version and update your previously created measurement reports, then more metrics should be reported and hopefully pass... The evenness metrics should now work for your charts, and also the grey balance metrics when a verification chart is created using "From Profile's Gamut" that has s single ramp of neutral grays.
Cheers,
Knut
Cheers,
Knut
576 Patch Chart
Left pic is "within-gamut-colour"
600 Patch Chart
My understanding is that the 576 Patch Chart (not 572) target chart does not contain sufficient neutral grey patches when sampling with the “Within-Gamut Colour” option. Consequently, the grey test cannot be performed as part of the verification test.
The left image of the 576-patch chart shows 585 patches, which is understandable given the calculation of 13 × 9 × 5 = 585.
ChromIQ adds up to eight white patches to fill the vacant spaces.
The left image of the 600-patch chart shows only 576 patches. Shouldn't it contain 600 patches, based on the calculation of 12 × 10 × 5 = 600?
Which patch set delivers better colour reproduction in real-world printing, beyond the verification test?
Hi @jctay ,
All profiling in practice has shown that having a ring or near-neutral greys around the ramp of neutral greys clearly improve the grey balance on the profile, so the 600 patch chart is better.
That is why I hinted to you in my last post :) to compare the report output of the two verification measurements you did (for your two projects, one with the 576 patch set, and the other with the 600 patch chart). Then we could all see if the results were improved. :) That would be interesting to see, as nobody has done such a comparison with two profiling runs with a very similar size charts, but a clear difference on the grey ramps.
The bug in the measurement report that stopped the report from calculating the two grey balance metrics when using the 576 patch chart is now fixed I think. If you update one of the measurement reports for on the verification run you did with that chart you should now see the numbers for those two metrics.
Cheers,
Knut
Hi @jctay ,
Cheers,
Knut
ChromIQ v4.3.10
OK!
This release generates 48 strips, so the total of 576 patches (12 × 48) is correct 🍻
The page layout looks good :)
I guess that chart's last page has room for two more strips of 12, making 600. I would always make a chart that fills up all pages.
You can easily copy another preset's patch set (which has 600 patches) into your chart, which then would fill the two last strips. If you go to Tools --> "Edit / create chart patch set" ,
then click "New Patch Set..."
then in the window where one normally would generate a patch set, look for and select a patch set with 600 patches in the "Load setup from preset" pulldown:
Then click
This loads the patch set in the Patch Set Editor. Now just click "Apply / Save..." and "Overwite" in the popup.
Now you would have 600 patches, and a copy of the same patch set used in the preset you chose.
You don't have to do this, of course :)
Cheers,
Knut
Back
