I CAN have nice things, right?!?! Pulling the trigger on a Bambu Lab H2S
Brother MFC-L8690-CDW
Sell it, you won't lose much $$$. The AMS and the wastage is a definite disadvantage. I bought the Snapmaker U1 on a whim and it has been a real eye opener. Virutally no wastage on multicolored prints and a system that works and is easy to use. I agree though that most people print single coloured prints for a lot of the time.
The Snapmaker is also almost completely open source and already has a great third party firmware that amongst other things allows you complete remote control over the printer, inclusing a virtual copy of the LCD screen. You can do everything remotely, except of course changing the filament when a spool runs out :)
On another note there is a fork of Orca that allows a 4 colour multi toolhead printer to print many other colours, currently on the U1 but I'm guessing it won't be long before a version is created for Bambu etc.
There are definitely parts of me that feel a little uncomfortable having a big, huge expensive monster printer in one room that I don't use very much, and then a tiny printer in this room that I'm using all the time.
Mostly I print just one colour, and if I have a need for a second or third colour it’s not that hard to swap out one for the other, the only down side with this type of operation is you have to be there to physically change the reel box..
I taught with the direct feed extruder it would be harder to change from one colour to another, but I was wrong, it’s easier and more efficient than even..
No mishaps so far..
I also had a few very small printers to do things while my bigger ones were busy doing something else, but because they were used so little, they tended to play up and needed far more handling and pulling apart, so they ended up in the dumpster in the sky..
Here are a few multi-colour prints that I did since I got my new Ender-3 Plus, some of these prints were done back in 2018 and need updating..
P.S. I can’t remember the last time I did a photo on my inkjets..
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
One of the main reasons I got the H2S is because of the huge print bed and that it's an enclosed printer. Using multiple colors was kind of a side bonus.
Yep, same for me too.
In fact I just finished a project where I did multi-colors per layer like you have in your great examples and it worked just fine on my A1 Mini.
Tony4597
Cheshire, UK
Epson Surecolor SC P800
Sorry to hear you are having issues with brittle filament and breakages. I am sure you have probably looked into it but from what I hear the AMS 2 appears to have issues with brittle filament which may not be apparent using alternative filament paths.
The main issue appears due to moisture absorption and/or aged filament. I understand the AMS has its own drying feature but this may not be enough and thorough drying by other methods may help?
Administrator
Bay Area CA
I've never had success drying filament that is brittle and it becoming less brittle. From the research I've done there are a few other things that can cause filament to get brittle that are independent of moisture and humidity.
I end up tossing some of the filament but there is some that is just a little bit brittle that feeds fine into my Ender-3 and now into my A1 Mini.
That’s something I’ve never had a problem with, so maybe the issue you might have is the lack of or to little moisture, it’s something you might not think about, we never get low moisture here no matter how hot it gets in any season, (The max temp here 23c on very, very rare occasions and humidity 98%). The normal humidity here sits at 50%..
Tony4597
Cheshire, UK
Obviously not having this type of experience directly printing with PLA I can only hazard a guess what the issues may be. I do not consider I have the answer to your issues but....
I would not completely rule out the possibility of moisture induced stability issues with PLA with the AMS unit being a large contributory factor. I would suggest that the path the filament has to take in the AMS is more torturous than in either the AI 1 or Ender units. Additionally there is the movement of the filament feeding from the spool and retracting putting pressure on a filament that may be already under stress.
Curious, does your brittle filament act like this
You mention filament that is just a little bit brittle feeding OK in your other printers which seems to agree with the point above about the journey of filament from spool to nozzle.
1. PLA is hygroscopic (mild compared to some such as TPU). So over time the absorption of water leads to hydrolysis that breaks the polymer chains resulting in the filament becoming brittle. Can also cause filament to pop/blob as water is heated in the nozzle
2. I believe it is possible to over dry filament by using the wrong temperature, or too long or too often which may be an issue with some filament
3. UV light can make filament weaker
4. Colour of filament (Dyes and filler) may change how it performs
5. PLA is sensitive to heat so can potentially harden and break more easily
Whatever the cause of the brittle filament my best guess (and from research) is that using this 'compromised' filament in the AMS exacerbates the issues
Administrator
Bay Area CA
Sorry @Tony4597 I didn't see your reply.
yes, it's completely acting like that where it snaps when bent.
... But I am almost positive it's not moisture related, at least not in a way that I can fix. I have done tremendously long dehydration cycles and processes with this filament and it still acts the same.
It's either old or degraded due to UV exposure, etc., or just a bad mix/batch.
Fortunately, I was able to go through the roles of the questionable filament on my A1 Mini since I have it loading directly into the printhead. In the event that anything gets broken or stuck, I can easily push it through.
I suspect its just a bad batch. I have never had any moisture problems here but have had a couple of rolls with very brittle filament which after drying was the same. the next roll from the same manufacturer was fine.
Administrator
Bay Area CA
Agreed, most likely a bad batch.
I'll admit that I have some rolls of PLA that are pretty old (still in the vac sealed and in temp-controlled cabinet)... but I'm sure that some of them were brittle relatively soon after I got them.
