I CAN have nice things, right?!?! Pulling the trigger on a Bambu Lab H2S
chaos_engineer
Anycubic Photon Mono 4k
Can you print some anti vibration feet for it to help with the shaking? Use your old printer and run them in TPU. See if that helps. Even on my little (by comparison) A5M, the feet made a big difference. I notice in the vid that @Tony4597 shared, 2 of those printers also have what looks to be green TPU feet.
Tony4597
Cheshire, UK
Epson Surecolor SC P800
If you have not found this site you may like the content and the explanations of the finer settings. IMHO worth a look around
The 6 Most Important Settings in Bambu Studio 2.3
Discover 22 Bambu Studio Tips That Will Upgrade Your 3D Printing
Tony4597
Cheshire, UK
I was a little alarmed when I saw that my P1S danced about under certain loads on the table, which is not really that substantial being a cheap IKEA unit. Movement of these printers is very noticeable after coming from something like the early Creality A30 etc.
Reading others views about this tbh little confused if the efforts really make a big (or any) observable improvement to print quality. I cannot fault my wobbly printer on its original feet for print quality but have to say have not tried any other feet or table improvements.
Bambu own feet I believe these are the standard replaceable fitted to H2 models
Anti Vibration feet
https://uk.store.bambulab.com/produ...UUVGx_epPuPHskQB9AjUnpOoDV2ecg_YGB3O8H_wU_dLY
FWIW here are some of the comments recommendations I have seen:
  • Vibration damping feet are not supposed to reduce printer vibration but rather reduce vibrations transmitted to the surface that the printer occupies.
    They are useful when you have another or several printers on the same stand and wish to minimise/eliminate vibrations so as not to affect others
  • Vibration damping feet actually make the printer vibrate more so if you are not concerned with vibration transmission you can leave them off
  • Several recommend putting a heavy paving stone or similar under the machine to help with vibration
  • Set it to Ludicrous speed and watch it dance
Heres one on a flimsy table that needs to be beefed up IMO
https://packaged-media.redd.it/9lyp...00&s=b2c3c17ef0b36c0ed41ff611ec69e51b11156e36
What about print your own that are not quite as flexible as the fitted feet and try on a paving slab on a stable platform like these?
https://makerworld.com/en/models/12...ration-tpu-feet?from=search#profileId-1321257
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
Wow guys, thanks for all the great comments and support!!!
As far as the noise is concerned you will find it a lot quieter with the slower print speed modes. It's all very well printing at insane speeds but better quality and less noise are a product of slower speed printing.
Good reminder about speed/sound. That said, my issue is the SUPER loud CLICK CLACK the printer does a bunch of times while it's prepping for a print. The AMS respooling is also pretty loud. The actual printing noise level is quite manageable.
I know very little about Bambu's but as far as printing TPU is concerned I believe it is best to avoid using the AMS for TPU.
Correct! I'm looking into options for splitting the PTFE tube and bypassing the AMS to feed directly / as close as possible... but without having to disconnect the existing PTFE every time (which is Bambu's suggestion). I'm holding out since I don't print TPU a lot, but I'm thinking I'd like to print with it more often since I really like it.
I'd also look into adding an internal filter to cut down the VOC's
yep, that's on my list to look into, especially if I start doing ABS... maybe even a duct going directly into a good air filter / purifier.
My first thoughts too, taking a long time to start printing. You may notice in Bambu Studio that the preparation time for a model remains the same regardless of the size of the model. In the case of the example image prep is 7min 10s for the small benchy and exactly the same for the 4x enlarged Benchy.
Yup, exactly! I'm trying to change my behavior. In the past, I'd only print one model at a time because startup was fast and the probability of failure of multiple models was high. Now I'm in the complete opposite situation where the printer is super reliable and I can cancel individual items, but the startup takes a long time. That being the case, I'm trying to do more models of the same color at the same time to reduce startup. Of course, that said, everything is so set-and-forget. I can just start it and walk away, and the time doesn't really matter.
You can reduce the time prep time in the next screen if you want by selecting no bed levelling (not a good idea IMHO at least for a first print in a series)
yep, that's exactly what I've been doing. :)Once I've had the printer and filament calibrated, I Usually have subsequent calibrations turned off.
Not sure what youo mean by already calibrated and turned calibrations off, could you explain please?
Meaning that the printer bed and filament have already been calibrated, so when I'm printing a new part, I disable or turn off the recalibration options.
Yep, there are so many settings that can effect print outcomes I am still struggling. Plenty of good advice on the web though (along with the bad!!). Up till now Orca and Bambu have been very close. If this will change due to what appears to be a split remains to be seen. Of course if you want Orca you will need to go to LAN mode only
yep, I've been watching a ton of beginner tutorials and will start going into the more advanced ones. Fortunately, a lot of the stuff that I know from Cura carries over. It's just a function of trying to find where the settings are.
I did notice that on my first play with P1s and it came as a bit of a shock. However this does not affect print quality in any way that I can see and my assumption that this has been taken into account in the set up process, input shaping?
Yep, I figure they accounted for how much everything shakes and built the frame and everything else to account for this. People have thousands of hours on their printers with no complaints about them falling apart. ;)
As I have never tried TPU I can only go by what others have said:
There is a dedicated TPU inlet on the printer.
Use this for TPU 95A, you can also use the main rear inlet, but you have an AMS connected that that.
I'm a huge fan of TPU. I think it was Maker's Muse that talked about using it in place of other filaments because of its durability. I just wish it wasn't so hygroscopic that I have to baby it.
Did the same 0.8 although so far not tried them. The nozzle change is more involved on the P1S
I have a 0.6 nozzle coming today that I'm excited to put in. I've basically only been printing with 0.6 for the last few years. I also ordered a 0.8 to see how that goes, but I've heard mixed reviews on it being significant diminishing returns on quality.
You will find divided opinion on plate cleaning. Basic recommendation is just soap and water and dry. Some advocate never ever ever use IPA. I have been using IPA for years without issue and prefer it for speed over washing a plate (which I think is Bambu rec.).
I wonder what Bambu's official stance is on using IPA. I too have used it. I too have used it forever and been pretty happy with the results.
Your WOW experience is exactly what I had with the P1S and still get when a print comes of the plate. I am sure over time you will come to find the odd feature that you wish was different but I am pretty sure your experience will echo mine with Bambu
yep, it's only been one day and I'm feeling that way. It's pretty crazy that I can just start a print and not even care about what's going on without checking the first layer or anything. Such a divergence from ten years ago. They really did a great job moving the needle on this hobby.
I've considered buying the ones from Bamboo or maybe even printing some out of TPU, but I don't know that they help with the shaking. I'll have to look into it more.
funny, I had already visited those before reading your post. There are some really good video collections out there that I'm going to go through that get deep into Bambu Studio.
Administrator
Bay Area CA
I've been super enjoying my H2S. It works amazingly well. I've also been getting up to speed with Bambu Studio and am pretty happy with it.
Today I had an interesting situation.
I wanted to print something using a small roll of silk PLA, but the roll doesn't fit in my AMS and I don't have the side spool holder set up or really accessible.
Well, I still have my Creality Ender-3 V3 SE set up and decided to throw the spool on it. This was actually faster than dinking around with the external spool and feeding filament, etc, through the PTFE tube.
I've also been running into some problems with some brittle filament breaking in the AMS and various PTFE tubes. While not the end of the world, clearing them out is a bit of a pain.
Now it's got me wondering...
I picked up an A1 Mini. I picked up an A1 Mini for $199 when it was on sale and am planning to return it since it's not open. But then I realized I could just put this in place of my Ender-3 and have it close to me for quick small prints, which are like 70% of what I do.
It would be convenient having it right next to me and would solve some of the issues with the brittle filament that I want to use up and the other things like TPU printing, etc, that don't work in the AMS.
... But this is also something I was trying to avoid in the first place by having two printers.
Decisions, decisions.
I solved that problem by getting 3, all the same…
They work well together, and still have one spare.. Picture 8.jpg click to enlarge..
Tony4597
Cheshire, UK
Ahh, so begins PAS which can only end when you start your farm :celebrate
Epatcola
various
There a many small (250g) spool adapter designs to fit the AMS (including this one of mine for EONO spools).
If PLA is breaking in the AMS it is probably brittle from being damp. That said I always pull PLA out of the AMS feeders when not in use. Constant pressure from the feeder gears and/or moisture ingress from the broken surface weakens the filament and it has quite often broken about 5 inches from the end. I don't have that problem with PETG.
Administrator
Bay Area CA
So I found myself a little less excited about using my H2S... Mostly because of the AMS and dealing with managing the filament, especially any that is even a TINY bit brittle.
I've already had a few scares and problems where I had to dismantle things to pull out tiny broken pieces of filament in the AMS.
Fortunately, I've got it working, but again, it makes me less excited to dive in and print stuff. :(
That being the case, I finally decided to just open up the A1 Mini that I bought on sale for Black Friday and never ended up opening or returning. I think I might be happy printing again. :)
I basically pulled my Ender-3 V3 SE off of the IKEA cabinet next to my desk in my office and put the A1 Mini there. Dang this thing is so effing tiny and cute!!
I'm realizing that 99% of the time I'm doing single color printing, and even if I do need to swap colors at a layer, it's super easy with this printer. Also, I'd say about 85% of the stuff I print will fit on the A1 mini bed. It's also way easier to manage and unclog if I get any filament breaks or jams.
There are definitely parts of me that feel a little uncomfortable having a big, huge expensive monster printer in one room that I don't use very much, and then a tiny printer in this room that I'm using all the time.
