Using ArgyllCMS + Colormunki to produce excellent printer profiles
nrdlnd
Epson Stylus Pro 3880
Even so, my 3880 gives virtually the same colour gamut (918,035) on a reasonable microporous RC paper.
So comes a very obvious question about making profiles from papers with a lot of optical brighternes as I think all RC-papers have. This thread started with making profiles with the Colormunki that has an UV-cut filter. As I've understood it this instrument can't read a part of the blue/violet spectrum as the UV-filter also cuts off some of the blue/violet spectrum. I bought an i1 Pro instead without an UV-filter. In the Argyll documentation it's recommended to buy an instrument without UV-filter if you have the alternative . When you make a profile with a paper with optical brighteners it's possible to make a compensation (UV-cut?) in software (Argyll CMS) instead.
I try to use papers without OBA but for some 'everyday' prints I want to use RC-papers as they are a lot cheaper and often very good. How important is it to make this compensation for UV? What commands or arguments should I use? Is it necessary to measure the OBA-content of the paper to be able to do a satisfactory compensation? Is a profile made with an UV-cut instrument (like the Colormunki or the i1 Pro with UV-filter) correct when you make a profile with a paper without OBA-content as the filter cuts off some of the blue/violet spectrum?
One of the reasons I'm asking this is because I have problems getting the colors correct on the RC-paper I'm using (SIHL Masterclass Lustre).
Per
RogerB
S.E. England
Epson Pro3880
Per
I use a few papers, some OBA-free and others with varying amounts of OBA. Like you, I have an i1Pro without the UV-cut filter. I have to admit that I never try to compensate for OBAs when I make a profile with Argyll and I have never had any real problems.
I recently profiled four RC papers from the Harman CrystalJet range. These papers have lots of OBAs - the paper white measures (L*, a*, b*) 95.9, 1.5 -11.0 The profiles give very nice results for both colour and B&W so I have not felt the need to tinker with OBA compensation.
What kind of problems are you having with the Sihl paper?
nrdlnd
I printed a series of pictures and I couldn't get the colors exactly right as I wanted. I tried to tinker with them in Capture One but I didn't really get it. I came to the conclusion that it was the difficult lighting conditions that made it. I haven't tried to print on a paper without OBA so I can't say that it was because of the optical brighteners. The people that got the pictures were very happy so maybe it's only me!
I wanted to ask if someone else have had the same experience. I also have a general interest to know if it's important to compensate for UV and how to do it. When I made profiles for the SIHL paper I tried the argument '-f D50M2' but when I printed I couldn't see any difference between the two profiles. I haven't analyzed the profiles with Gamutvision though. I didn't use illum as I didn't want to measure the papers. I don't quite understand the documetation in Argyll on how to compensate. If it's not necessary I will not bother.
As a bynote I have printed my first series of pictures on the mattte Museo Portfolio Rag with my own profile (576/1152 on 3 papers) and the result is very good for a matte paper! I couldn't wish for better!
Per
nrdlnd
I looked at the two profiles with the RC-paper SIHL Masterclass Lustre in the trial version of Gamutvision. One with the command '-f D50M2' in 'chartread' and one without. I'm not sure if this is the correct command to get a standardized FW-compensation without measuring the actual OBA content with 'illum' that seems rather complicated. There is a difference between the two. D-max is slightly higher with compensation but there is a difference in the way gamut looks in the red/violet area (the one with '-f D50M2' has more gamut especially in the red area the one without very slightly more in the blue area). The '...OEM2.txt* is the one with 'FW-comp' or with the above command. The one with compensation has a little greater gamut overall. Is this result according to theory?
Per
  • Epson3880SIHLLustrePhotoPaper300OEMingenUVcomp.txt
  • Epson3880SIHLLustrePhotoPaper300OEM_2.txt
knowing
HP CLJ5550, Brother MFC-9460
Hi @pharmacist and everyone on this thread,
I recently got me a new and unused Colormunki Photo, as SpyderPrint was too much hazzle.
I found a farily simple script on github AutomatedArgyllPrinter, by Jintak Han. I used this as basis for creating a much more advanced version, see link below. These are made for mac os, and aimed at Colormunki.
However, menu choice 2 to 5 can be used by other instruments supported by Argyll. Menu choice 1 in my script presents a set of pre-defined targets to generate, with Colormunki in mind. Many settings can be configured, and anyone is free to modify the script to their liking, but it would be cool if that work is shared on the forum, if anyone does.
Hope someone will test it and give feedback. Sorry, I do not have windows, so this is not for you that only have that.
The script works well for me now, but I am sure bugs exist (log file content is not ideal I noticed). There is a ReadMe.md file for installation help and user guidance, but a lot is self explanatory.
The project has now been published on github.com and can be downloaded from:
https://soul-traveller.github.io/Argyll_Printer_Profiler/
Cheers,
K
My Windows computer says NOOO....cannot have a look at it, Apple only.
crenedecotret
I had a look at the script. It will ask you what device you are using and how many patches you want. It then holds your hand a little bit, explaining each step like printing, starting chartread for you, etc. I could probably make something with powershell or python (to make it portable) if your interested but I think the batch files and charts you already created years ago will do a similar job for an i1pro or colormunki user
