TI1, TI2, CSV and printtarg target files for SpyderPrint Targets
knowing
HP CLJ5550, Brother MFC-9460
Just to let everyone know,
If you or anyone are interested in the color data for SpyderPrint targets, then I a script "read_image_patch_colors" that extracts color values from a rectangular grid of color patches in an image, computes colorimetric values (RGB percentages, XYZ, Lab), applies row/column labeling rules, and writes three output files:
  • ArgyllCMS .ti1 file
  • ArgyllCMS .ti2 file
  • CSV file (space-separated)
You can find the script here:
https://soul-traveller.github.io/read_image_patch_colors/
There is a folder "Example Targets Read" which contain most of the SpyderPrint targets, as well as the generated files. I have used it on the following targets:
  • Expert Target (3-pages, 729-patches)
  • Expert Target (large) (1-page, 729-patches)
  • Expert Target Plus Grays (4-pages, 967-patches)
  • EZ 729 Colors Plus Grays (9-pages, 996-patches)
  • High Quality Target (1-page, 225-patches)
  • High Quality Target Plus Grays (2-pages, 463-patches)
  • LaserSoft Advanced Target (864 patches)
I have also updated the release in the link with many printtarg targets based on .ti1 files made for SpyderPrint and LaserSoft Advanced Targets.
Hope this is useful for you or anyone in the forum.
I made this as one step in a plan to try using SpyderPrint measurements, and then use the output for ArgyllCMS to create profiles. I am not there yet an not sure I will ever finish that work.
Let me know if any bugs or problems are found.
Cheers,
K
knowing
Cheers,
K
Unfortunately, I found a big error in the code. I suspected something was up when I saw the dull colors from the LaserSoft Advanced printtarg targets.
Datacolor SpyderPrint documentation specifically instructs to print images with "Generic RGB Profile.icc" profile when intending to read back with the hand spectral scanner. This implies that the images have been created with "Generic RGB Profile.icc", which uses gamma 1.801 and a linear matrix
Xpcs | 1,047882. 0,022919. -0,050201 | Xsrc
Ypcs = | 0,029572. 0,990494 -0,017059 | Ysrc
Zpcs | -0,009232 0,015076 0,751648 | Zsrc
I have to reverse engineer the original RGB by inverse applying the matrix and removing the gamma. Currenty, the code assumed the output image was D65 sRGB with 2.2 gamma, which would also be very wrong for normal target images, such as those printtarg generate.
* Step 1: Inverse matrix (PCS adaptation), encoded RGB (approx. D65) → D50
* Step 2: Invert gamma (Encoded RGB (D50) → original (linear) RGB patch)
* Step 3: linear RGB (0..100) → XYZ (D50) output scaled Y=100
* Step 4: XYZ (D50) scaled Y=100 → L*A*B* (D50), L in ~[0..100], a,b roughly [-128..128].
Then use these three sets RGB, XYZ and LAB for generating ti1, ti2 and csv files.
So, I am working to fix this issue. I will notify when I have an update.
Please do comment on this, if I am wrong or need to do this differently, to get the correct reverse engineered RGB values from the SpyderPrint images.
Cheers,
K
Thanks for the update. I took some time to use PS to manipulate a bit in order to get a combined Spyderprint 729 patch Expert target with the 238 patch Extended patch target into 2 sheets of A4 for better scanning experience with the i1Pro1/2 spectro scanning table/ruler.
The extended grays target of Spyderprint should neutralise black and white printing even with printers that have no gray inks by measuring multiple color points of near neutrals/grays around the neutral axis and correcting for any color shifts in the grays (if your printer tends to print "neutral" grays with a color hue).
EDIT: I have removed the target set, because it is not properly generated and gives errors when scanning the target. Those who have downloaded this target set: do not use it.
knowing
nice @pharmacist :)
I was not able to generate this with 975 patches using printtarg, so I had to add data (black and white) to fill in the missing patches, so the result was 1012 patches over two pages. These are in the latest update, but I can add yours to the github release also.
Questions on the problem I have with the output of the script:
Do you have any idea if the color values that are output from the script are correct? Or maybe anyone else has knowledge about this?
As mentioned above, the script makes some assumptions that image that is read is encoded with sRGB D65 with 2.2 gamma, but that might not true at all.
Firstly, the images from SpyderPrint are RGB images. When using pillow image method in python the mode comes back as RGB (Not CMYK, LAB, Grayscale or any other of the supported modes: see Pillow image supported modes). This is the same as for printtarg generated target images. They also are RGB images.
Secondly, since SpyderPrint requires that the targets to be printed WITH color management using the "Generic RGB Profile.icc" (also attached here, in case you don't have it) , then the question is: is correct to assume that the images also are encoded with this profile. Is this reasonable?
Currently the script does:
  1. Sample patches RGB values from image
  2. Convert RGB to CIEXYZ (D50, scaled so Y=100) using sRGB space
  3. Convert XYZ (D50) to Lab (D50), scaled so L in [0..100], a,b [-128..128]
  4. RGB scaled to [0..100]
  5. RGB written to ti1 file
  6. RGB, XYZ and LAB (if specified) written to ti2 and csv file.
The output values seem quite ok, and the whole issue may not matter at all, since I use printtarg to create targets from the values for printing.
Some sample of patches from the ti2 file for "EZ 729 Colors Plus Grays 1 of 9 (108-patches)", show that extreme values seem reasonable:
Full Black
1 "A1" 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
Full Blue
3 "C1" 0.000000 0.000000 100.000000 14.310141 6.062584 71.427844
Full Red
7 "G1" 100.000000 0.000000 0.000000 43.604040 22.248685 1.393110
Full Pink
9 "I1" 100.000000 0.000000 100.000000 57.914181 28.311269 72.820954
Full Green
19 "A3" 0.000000 100.000000 0.000000 38.506805 71.688445 9.710533
Full Cyan
21 "C3" 0.000000 100.000000 100.000000 52.816946 77.751029 81.138377
Full White
27 "I3" 100.000000 100.000000 100.000000 96.420986 99.999714 82.531487
Steps between extremes also seem reasonable.
Maybe everything is ok then, and I overreacted.
Appreciate any thoughts. Thanks.
Cheers,
K
  • Generic RGB Profile.icc.zip
Just to say the above target is not usable, because it gives reading errors,probably the conversion is not done well:
There is something wrong in the conversion. I have tried both the i1Pro1 and the i1Pro2 and the errors are the same.
Please check your ti1 files
knowing
Hi Pharmacist,
Thanks for testing. The format and content of the ti1 and the resulting ti2 from printarg look fully compatible and same as many other targets posted on this forum.
I found that my script ouput XYZ and LAB values in D50 illuminant. Many example TI1 files I looked at specified the key APPROX_WHITE_POINT "95.106486 100.000000 108.844025", which is D65.
I modified the code to support both D50 and D65 value output.
I ran then read_image_patch_colors.py script again, modified the ti1 file with som missing patches at the end, and ran this command:
Bash:
printtarg -v -s -M10 -p210.0x297.0 -r -ii1 -T300 -a0.93 "Expert Target (large)(2 pages - 989 patches)-i1"
I have attached the output. Could you please try this and see if you have the same issue now?
A couple of questions:
1. What was the printtarg command you used to generate the 975 patch version of the "Expert Target Plus Grays for the i1? I was not able to get printtarg to fill both pages fully, so I had to fill in another line with data, now 989 patches.
2. At which patch on the page do you start scanning from, and move towards to complete one strip? and do you have the page landscape in front of you? I'm just wondering what Label number is expected at the first strip, because for the SpyderPrint targets the page is landscape in front of me and scanning starts at A1 at the top left, then moving along row 1 through to last column letter.
However, when the target is printed as A4 portrait (then turning it to landscape in front of you) using printarg, then the sequence is mirrored compared to the the SpyderPrint sequence:
Here the direction of scanning I assume must be from right top corner, and moving towards the left, in order to follow the expected order in the TI2 file.
If this is wrong ordering, it is possible to experiment using read_image_patch_colors.py script, because I have built in functionality to flip entire patch grid 90, 180 or 270 degrees, or mirror, and also read columns then rows or rows then columns from the image. This should allow playing with getting a desired order in the ti1 file.
As soon as we fix this issue, I will release a new version of the script and all the example files.
Let me know if you have more trouble.
Thanks
K
  • Expert Target (large)(2 pages - 989 patches)-i1.zip
knowing
Sorry, @pharmacist
I forgot to update the last two tables of the ti1 file with D65 related XYZ values. I replaced the zip file in my previous message.
Hope this works.
knowing
I found the problem. Try this. The 729 patch ti1 file was generated with a wrong input coordinates on the target image, thus the data had errors. It should work now.
Tell me if all is working, then i will make a new release with new example files.
I would appreciate if you also tell me the printtarg command you used for your 975 patch target :)
thanks.
Cheers,
K
Could you upload the combined and corrected expert plus extended grays ti.1 file too ? Note use D50 and not D65 for conversion !
knowing
Hi again,
That is the one I uploaded. Note the name "Expert Target (large)(2 pages - 989 patches)-i1" on the file.
Also,
In my research I found that chartread expects XYZ that is D50 illumination white point from the ti2 file. Anything else may cause larger error in reading patches. When the colorimeter measures and delivers XYZ to chartread, this is assumed to be D50 and then calculates LAB with that as basis, and also compares with the XYZ in the ti2 file. If the ti2 file would be based on D65 or other illumination, the scanner would also have to deliver measurements with same illumination, or comparison will give greater errors.
I now changed the code to use ArgyllCMS xicclu in stead of colormath python module, which is more accurate. xicclu uses D50 also, so currenlty, the code does not deliver anything else than this reference that the ti1 and ti2 file specification uses, and chartread expects.
If you have other understanding, please let me know.
Thanks.
Cheers,
Knut
