micronica
EPSON L310 L365
Found out what the problem. Printing and scanning just before that. Printed old 228 patch scrambled… After that printed newest yours 266 non randomised patch, scanned and white is 85.xx. But still looks weard. Will post icc and ti3 at work.
I suggest to try to make profile on normal paper and compare it to an exisiting profile you use for that paper type and see if your modus operandi is done properly. Normally those profile should overlap each other more or less. I have don this with several paper/ink/printer combination and the procedure is legit and repeatable. Also printing with the profiles (CR30 vs i1Pro) is identical to my eyes with the same paper/ink/printer combination.
micronica
EPSON L310 L365
All files. Photoshop also shows no adjustment for white so why it gives me grey hue in white part of the photo?
  • 266-correct-spacing.csv.txt
  • 266-target.ti1.txt
  • 266-target.ti2.txt
  • 266-target.tif.txt
  • 266-hh.icc.txt
micronica
EPSON L310 L365
Hi
Kodak Ultra Photo Gloss, L365 regular, EPSON ink looks fine to me. U can check if im correct from attached files. Thx for all he help :D. So my files and messurments workflow is fine just sublimation ink have problem for some reason.
  • L365_KODAK.icc.txt
yes the workflow is ok, but the sublimation ink: most use a special RIP to print the pictures on textile. NOTE: the target must be measured AFTER the sublimation is transferred on the T-shirt and properly dried and cured and THEN you measure the target, because this is the end result.
micronica
EPSON L310 L365
Yes i know i need to messure after sublimation 😉 Problem can be textile itself becuause it’s txture. Rip is fine when u use cmyk or even more colors for what i know. Regular printers converted to sublimation act as regular one but colors show after sibli. Black are brown, grey are silver and so on before siblimation. Today i will try on pure poly textile and other material.
micronica
EPSON L310 L365
Another test diffrient textile thick 100% poly.
  • 100_poly.icc.txt
Epatcola
various
Can you generate the ti3 file using a scrambeld patch set from the original ti2 file ?
Today for the first time I printed and measured a target. The target was randomized and I couldn't generate a profile.
I think the build_profile script is not doing the right thing.
The patches are randomized on the sheet and the ti2 file has a SAMPLE_LOC to tell you where they are on the target.
I think the ti3 SAMPLE_LOC should be where the patch was on the target, that is it should start at A1. Not a copy of the ti2 locations.
OK, so for the moment only non-randomized patches will work. This is not a big deal, but when using several grey steps, because the hue increased with each following patch with a little but and sometimes without spacebars it is difficult to determine the end/beginning of the next patch. Therefore I have uploaded a modified i1Pro based target with tiny space bars between the patches making it much easier to determine where the next patch is starting.
micronica
EPSON L310 L365
Works fine if u use proofing on lowest settings. I don’t know its a big or what but it finish fine
