How to use an unlicensed i1Pro spectro with i1Profiler and ArgyllCMS
A lot of second hand i1Pro spectrophotometers (both the older i1Pro1 and the newer i1Pro2) have no license for RGB and CMYK printer profiling (in best cases only the monitor profiling option).
Not everybody is found of the ArgyllCMS cryptic commands to create printer profiles, despite the generated targets are to me far superior to the ones created by i1Profiler (especially the strange patch generator that tends to completely throw away all grey patches when you increase the patch count with just 1 extra patch from let's say 24 to 0 grey patches in favor of more colored patches). But the great advantage of the i1Profiler is the visually more intuitive graphical user interface and the driver gives you flashing lights (green, blue and red) to show you the scanning process much more easily than the rather muted sound signal the ArgyllCMS driver does (no flashing knobs :lol: ).
For this install any version of i1Profiler (the most current version is 3.8.5. NOTE this will be probably the last version that still will support the i1Pro2, because from january 2026 on the i1Pro2 is no longer supported by newer versions that will only support the i1Pro3. The i1Pro1 is only supported by version 3.1.1 or lower, so I suggest to use the last version that still supports the i1Pro1 that is the 3.1.1 version.
DISABLE the automatic upgrade search after installing your version of i1Profiler, because that will render your spectro useless (i1Pro2: stick to version 3.8.5 and i1Pro1 with version 3.1.1).
Now change to the advanced profiling option in the software and choose profiling:
For this example I choose my saved workflows instead of the patch generator (you can use this to start with), but I prefer the TC9.18 (GretagMacbeth standard target) with 918 patches and especially with extra near neutral and stained gray ramps that are not generated using the standard patch generator:
Now i1Profiler asks you to calibrate your spectro:
for sake of demonstration I have loaded my previous data (mxf) into the software so you can see the readings in i1Profiler:
What you want to do now after succesfull reading is to choose the save button (below the "page data" on the lower left) and export as "i1Profiler CGATS Spectral" txt file. This is very important !!! Preferable into a directory where you want to type in the coming ArgyllCMS commands to generate your profile, as an unlicensed spectro prohibits the creation of printer profile and you are stucked, but the ArgyllCMS software comes to the rescue:
now open a dos-box because now the typing in argyllcms begins: I have moved the exported M1 version of the spectral data (depending on your version of the i1Pro i1Profiler will export in only M0 (UV-cut): I1Pro1 or in dual scan M0/M1/M2: i1Pro2 versions of the reading:
For demonstration I will change the very long file name into a shorter name: testprofile.txt
Now type in: txt2ti3 -2 -v testprofile.txt testprofile
This command will convert your file into the ti3 target that argyllcms needs to create your profile:
Now it is time to create the printer profile. Use colprof and the corresponding arguments or....use my easier to use makeprofile.bat to create the profile:
now wait for the computer to generate the profile:
Your profile is now created: I use almost the same name of the original exported file name, but I change the i1Profiler into ArgyllCMS so I can now compare the profiles with the gamut viewer option in i1Profiler. NOTE: ArgyllCMS will only create version 2 profiles, but this is no problem in actual printing. First I will load the i1Profiler created profile:
Now I will import the profile generated by ArgyllCMS from the exported data that is read with i1Profiler software:
Since the data is based on the M1 version of the exported file we will choose M1-D50 version because it is an external profile now made by ArgyllCMS:
The profiles are near identical (note: because of the conversion from 0-255 values into the 0-100 values in ArgyllCMS there is a slight but unnoticeable difference):
Have fun with creating your profiles by scanning with i1profiler, export the data to an CGATS spectra data, convert it with txt3.ti3 in ArgyllCMS and generate the profile with ArgyllCMS.
I galnced through your detailed guide to use X-Rite and ArgyllCMS together which I like very much.
There is just a small correction necessary about in the middle of the posting
The M0 mode uses the UV light of the internal halogen bulb, the M2 mode is the UV cut mode filtering out the effects of optical brighteners. The intensity of the UV contents in the M0 illumination by the spectro is not clearly defined and varies with the age of the halogen bulb used for illumination, the M1 spectros use a dedicated UV LED with a defined level.
There are plenty internet postings about the measurement modes like these
https://www.xrite.com/-/media/xrite...ctor_what_does_it_mean/l7-510_m_factor_en.pdf
https://www.flexography.org/industry-news/m0-m1-measurement-modes/2/
https://onlinehelp.prinect-lounge.c...x/Version_CR/en/Prinect/devices/devices-5.htm
This morning I did a softproofing using both profiles: one generated with i1Profiler and the other with ArgyllCMS. For the sake of comparison I did not change the settings (like neutralise greys or pump up contrast color in the i1Profiler and saving in version 2 icc standard). Now which one does look better (rendering intent: relative colorimetric, black point compensation: OFF) and check especially on the neutrality of the greys and the contrast of the grey patches on a black background on the left lower side of the image:
However when using the 3D viewer in i1Profiler there is a slight off-set between the two profiles:
in iccview.de the ArgyllCMS generated profile has a slightly larger gamut and note the difference in white point value: not sure what is causing this (because same scanning data), probably because of the conversion between the 0-255 values to 0-100 values in ArgyllCMS and slight truncation errors. But the 3D models of both profiles are pratically identical and overlapping each other in iccview.de, whether the iProfiler 3D viewer gives a slight off-set between those 2 profiles. I think it has to do with the conversion in i1Profiler giving this strange off-set when projected in 3D and in iccview.de this artifact does not happen.
Asking for people with Fiery EFI-1000/EFI-2000 spectro (physically the same as the X-Rite i1Pro1/i1Pro2) if it is possible to use the above method using the i1Profiler software/driver and exporting the scanned data to a CGAT spectral txt format and converting it to ArgyllCMS proprietary .ti3 format and generating the profile using colprof.exe.
roncromberge
The Netherlands
🪦 P900 | 🚼 SC P5300
Hallo apotheker,
Again! Your the Live saver! A perfect explanation of this dark knowledge :ya:love:thumbsup
there is a extra benefit to use the xRite profile generating and reading tool is that in linux terminal argyll no audio or visual hints shows. And xRite show then very good.
Still waiting for my P5300 :confused: but got yesterday the confirmation that the printer is on his way.
And answering your question above.
YES. All the EFI spectro’s are 100% xRite apparatus. I have checked my EFI ES2000 with the xRite tools and where seen as normal xRites. including sn: and other readings. And in i1Profiler the device is seen a licence free device. —> only demo mode and screen calibration.
Yes I know: It would be nice that ArgyllCMS not only gives a sound but also drives the visual lights in the spectro to tell you the scanning is succesfull (green) or not (red). But now it is possible to generate printer profiles with this trick without a license for i1profiler, but you will need some command typing in a dos box using ArgyllCMS:
roncromberge
The Netherlands
🪦 P900 | 🚼 SC P5300
I'm one of the few in the world who worked with PC/MSdos 1.0 :) And many years experience with the early terminal based Linux distros.
Users of the vintage Gretagmacbeth Eye One Pro (X-Rite i1pro1 or EF-1000) need to use a older version of X-Rite i1profiler and that is version 3.1.1 or lower. Any higher versions do not support the i1Pro1.
Export in CGAT Spectral data txt format and use txt2ti3.exe to convert it to ti3-format and use colprof or my Makeprofile.bat to generate the printer profile.
ConradH
Canon PRO-100
Something else that works great with my Eye-One Pro (sold as EF-1000) are the now-free Bable utilities. I use the PatchTool V7 a lot!
crenedecotret
Question here... when saving the measurements, i1profiler offers two formats - one is i1profiler cgats spectral, the other one is profilemaker5 cgats spectral.
Considering that txt2ti3 was designed around converting gretag/logo and xrite colorport measurements, wouldn't the profilermaker 5 CGATS format be more compatible?
Edit: I just tested both. There is no difference. I'll probably save as PM5 CGATS because the tool is
"Convert Gretag/Logo or X-Rite ColorPport raw RGB or CMYK device profile data to Argyll CGATS data, Version 3.4.1" :)
