Tony4597
 - Jan 20, 2021
 - Cheshire, UK
 - Epson Surecolor SC P800
Thank you for your thoughtful advice which is much appreciated. That lamppost is fantastic and a real credit to your expertise. I bet you could also model the dog - surely TPU filament would be the way to goIf you are having problems with quality using PLA on your current printer, I’d suggest you experiment more because there’s no reason why PLA can’t print lots of things that can stand heat and water..
Even if you get a new printer, that won’t solve your problem, not will using other filaments such as ABS and others, in fact that may even make your problems worse, small cheap 3D printers can make items just as good as their more expensive big sisters.. (It uses exactly the same principal only smaller)
Thingiverse are great for all the things you can’t make yourself, but you still need to learn to make your own projects in time, use the Thingiverse objects by all means until you can get them to work the way their suppose too, failure is not acceptable, just keep trying, it will get better.. (It’s best to start small..)
(This was made with PLA)
P.S. Not the dog..
I bought the Geetech as it was cheap and thought that it would make a good starter to at least learn on. I have only ever used PLA and the majority of prints have proved to be at least acceptable. Problems experienced I have chalked up to lack of knowledge on my part. When I find them I will post some images of some of the items I have printed the faults I have found and what I think I should have done to correct them in the first place.
Only now am I able to find a permanent space away from the spare bedroom in the garage to place the printer. This will please SWMBO no end
I intend to design my own projects, I am quite comfortable (not expert!) with 3d CAD and have access to Solidworks and Turbocad and have flirted with Fusion 360
