- Thread starter
- #11
- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
It's the old age... happens to us all...Nice videos Martin, well focused and framed and straight to the point.
( The Hat, I didn’t need to RAISE THE VOLUME. )
Ah... Noted.. Classic example of assumption on my part. The actual kit we sell includes one syringe per colour but I took that for granted and didn't highlight it as a result.Some minor points, that I think it’s worth commenting:
1- In my experience, it’s best to dedicate a syringe for each colour, Cleaning the tip of the syringe with a cloth after refilling one colour isn’t enough to avoid a certain amount of contamination.
Those carts only have a max capacity of 20ml which I find to be a little too small a volume but I do have a big box of the ruddy things so perhaps I should take a look at the differences and heck, do a video on it2. Syringes with a rubber seal don’t last long. Ink solvents attack slowly the rubber, which bloats progressively making more and more difficult to push/pull the plunge, until you can’t do it anymore or the rubber seal gets unstuck from the plastic plunge. Not a big deal, just more syringes to purchase.
Anyway, there’re syringes with an all-plastic plunge (no rubber) that don’t suffer from this problem. although they don’t make a seal as good as rubber and sometimes a couple of drops escape from the back of the syringe if you push too hard. Choose your poison..![]()
Agreed... I didn't do my due diligence on that which is why there's the correction in the subtitles. I wonder if I fudged it a little by not committing to either filling by volume or by weight and not flip flopping between the two.3- All the pigments inks that I've tried ( Octoinks for PGI-72, Inktec, Canon OEM) have a density slightly above 1g/cc. I measured several of them and they ranged from 1.04 to 1.07 g/cc. Exception was your chroma optimizer for PGI-72 that had exactly water density.
For instance, 14ml of PGI-72 ink weight roughly 15g. ( or 15ml = 16g). Of course, 1g won’t matter much, but in the case of the Pro-1000, 80ml would range from 83 to 85g. and that’s already a sizeable difference.
