- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
Thank you for the feed-back. Sadly I'm out of ideas of what might cause the error.
do you think I could use a valve cam sensor from another model...Pixma MG5350 for example or from a MP610?Thank you for the feed-back. Sadly I'm out of ideas of what might cause the error.
Hello PeterBJ,Thank you for the feed-back. Sadly I'm out of ideas of what might cause the error.
Was the faulty switch similar to those found in older printers like the iP4000? I admit I have dumped a similar Canon printer with a 6C10 error instead of taking it apart and trying to repair it.the interest thing is that the switch didn'work properly as I mesured it with my Multimeter.I'm impressed.Was the faulty switch similar to those found in older printers like the iP4000? I admit I have dumped a similar Canon printer with a 6C10 error instead of taking it apart and trying to repair it.
Perfect.Ok, one little tip: A drop is per definition 0.05 ml, so 20 drops equals 1 ml. This means you need to add one % of ammonia. If you want to prepare 1 litre of cleaning solution then you should use 10 ml of ammonia. Instead of counting drops it is easier to measure the ammonia with a syringe or pipette.
