- Apr 19, 2007
- USA
- Canon MB5120, Pencil
I asked for clarification and you provided it.
I have no idea from your post if you understand the boldfaced text in my last post. It is one-half of the reason for volume discrepancies you have noted. There is more than one way for Canon to utilize or not the interior space of the cartridge for ink volume.
Do you weigh the cartridge before refilling? How do you know how much residual ink is in the sponge/cartridge and therefore how much ink to refill?
Disabling ink level monitoring is never a desirable thing to do. It is a last resort. It is manageable with continual vigilance. People who sell you ink are not going to be paying for a new print head or printer for you.
Given the OEM fill amounts per Canon, this is not strange at all. What did you expect?Just seems strange to me because only the sponge can absorbe at least 4 ml of ink.
Unless you are using ARC chips or a chip resetter, then eventually you will need to disable ink level monitoring for this model printer/cartridge to use refilled cartridges. You will always need to babysit your printer, as The Hat said, in order to be ready to stop printing if/when ink starvation occurs or else risk irreparable damage to the print head. Sooner or later you will need to flush the cartridge to restore good ink flow. This is the nature of your printer / cartridges.Also leaves almost always the upper part of the sponge unsaturated
