- Feb 4, 2014
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
I would wait to take other measures until the purge system works as @The Hat described: no fluid should stay there.
IMO no need to pull the power plug, just open the top and push the button as you change carts, you can access the purge system this way with a long syringe and spray Windex (or water with a few drops of ammonia, this seems to dissolve the ink) on top of the purge pads.
Let it soak overnight.
Since 8 out of 10 colours are OK, don't touch them, try to clean a PC and GY cart thoroughly as described and refill it again with Octoinkjet ink.
As you experienced it will work again.
Launch a nozzle check every morning and verify with a magnifying glass, you must see a regular dot pattern and no sign of swipes whatsoever.
