- Apr 19, 2007
- USA
- Canon MB5120, Pencil
I learnt love making the same way![]()
I not 100% sure but I don't think websnail is making those kind of videos.
Printer Potty Porn Productions?
I not 100% sure but I don't think websnail is making those kind of videos.![]()
Don't fix what ain't broke!I've never had a blocked nozzle or imperfect nozzle check during that time - and long may that state of affairs continue.
The reason you are getting leaks is that it is likely that the drill bit is either oversized it should be exactly 5/32" or you damage the seat at the bottom of the hole when removing the ball. If the bottom of the hole is distorted or nicked deeper than a few thou, the plug will be unable to conform to a sharp indentation. You are NOT to pry the ball out as is shown on videos, this is plain wrong. You should be using a screw eye hook to thread into the ball and then pull it out.An update on sealing the filling hole on Canon CLI-8 and CLI-42 cartridges if you have already prepared the hole left after removing the plastic ball from an OEM cartridge using a drill bit as per the instructions on Precision Colors website ie. using a drill bit to clean the hole out slightly larger so that the plugs fit properly.
I've found that in up to 20% of my cartridges modified by this method there was an imperfect seal around the plug which of course allows ink to drip from the delivery nozzle when the orange cartridge cap is removed. I don't know whether this is caused by the drill bit not being sharp enough or some other factor but this is what happened in my case.
My standard remedy for this seemed risky at the time but after over three years now and many refills of my Pro100 cartridges I'm confident that applying a ring of PVC wood glue (the water based one with thick consistency) around the plug rim after it is inserted such reliable method that I've been using it for all of my cartridges. I've never had a blocked nozzle or imperfect nozzle check during that time - and long may that state of affairs continue.
The PVA wood glue adheres on a the damp surface around the plug and does not seem to enter the filing hole. I take the trouble to wipe off around the plug with a tissue before applying the glue just in case the glue's consistency is altered by any surplus ink and when refiling time comes around the dried glue seal easily separates from the plastic cart and plug.
As a precaution (against micro-organism growth in the ink) I always store my spare cartridges and inks in a refrigerator but I don't know whether refrigeration is a factor when it comes to cartridge sealing issues.
