- Dec 27, 2014
- Germany
I have the chance to test and use an ET-7750 Epson Eoctank A3 printer for quite a while.
There are various test reports on the internet about this model so I won't repeat details of those
reviews but just comment on a few details.
https://www.pcmag.com/review/357449/epson-expression-premium-et-7750-ecotank-wide-format-all-in
http://www.photoreview.com.au/reviews/printers/epson-ecotank-expression-premium-et-7750-printer
The ET-7750 is a combo with an A3 print mechanism and a simple A4 scanner on top and is equipped with the latest generation of built-in ink tanks - refill is easy and error-free.
The unit as an A3 printer is not wider than a A4 photo printer L800 with the tanks attached to the side.
The body of the printer is somewhat deeper than the L800 because of the attached duplexer , the ET-7750 has about similar proportions like the Canon G1500 and alike.
The ET-7750 uses 5 inks - 4 dye CMYK and a pigment black, the printhead has 6 nozzle rows - 4 CMYK and 2 for the pigment black. The printhead ejects droplets with the min size of 1.5pl which is the same as the L800 and lots of similar photo printers, as well like the A3+ P400 unit and various Canon models.
The inks coming with this printer are labelled as Epson 106 (in Europe) and tests have shown that their fading performance is very good and similar to the Epson Claria inks but much cheaper in bottles than in cartridges. The pigment black is labelled as Epson 105 (in Europe).
The printer hardware is based on the XP-900 which is discontinued as such, it used the same 5 ink inkset and offered an A3 bypass print option.
The ET-7750 comes with a mixed set of options - it is not a real home office printer , and it is not a real
A3 photo printer - the A3 feeder at the back only takes a few sheets, the extendable paper support is very flimsy and lacks any paper guides on the sides. The ET-7750 comes with an easy replaceable waste ink/maintenance tank which is small, very small , about the size of 2x2 match boxes only, and the box carries a chip....so Epson wants to make some money on these maintenance boxes as well.
I compared the gamuts of the L800 and the ET-7750, they are the same within 2%, the print quality is very good, the dithering of half tone colors is very fine (depending on the driver settings), both types of printers deliver very good print quality.
Since I'm testing lots of options with the gloss optimizer, its benefits as reported in other threads, the idea came up whether the pigment ink channel could be used with GO instead of the black ink to have one printer doing the photo prints and the GO application. The only other Epson printer able to do that would be the P400 without modifications or tricks but with very small cartridges.
And here the problems start - the normal paper setting in the driver does not allow the printer to print borderless, all other paper types - matte and glossy - allow borderless printing. This is a limitation
when trying to apply a borderless GO overprint on a borderless print. But there is remedy for this
problem - the alternate Printfab/Turboprint printer driver for the XP-900 supports as well the ET-7750 and offers the borderless option for the normal paper selection.
And there is a 2nd problem - the driver with the normal/Copy paper selection does not just prints with the pigment inks but adds some of the black dye ink as well. When filling the GO into the pigment black tank instead of using the original black ink the driver still prints a medium gray when printing 'black' with GO on normal paper. There is apparently no way around this, no driver settings, and not even with Printfab , will let the printer use the pigment black only. The only way would be to block the ink flow of the black dye ink to the printhead by using a spring loaded clip on the ink tube as long as the printer just should print the GO.
So my feelings for this ET-7750 are quite mixed, the inks are very good, the print quality is very good, but all the other options combined are by far not optimal for this model.
