- Jan 18, 2010
- Residing in Wicklow Ireland
Head clogs are very strange things, first how do you recognise a clog ?
Canon print heads seldom clog and when they do, it is usually from lack of use, running a normal head clean is usually all that’s needed to get the printer back working again.
If by any change the head still looks clogged, (Poor printout) then 1 deep head clean will clear it up and all should be well, but if it’s not then more than likely it’s not a clog at all, don’t try running several deep head cleans because that can cause you even more headaches, read more...
98% of print issues are directly caused by poor cartridge performance and continually running deep head cleans without a sufficient supply of ink flowing to the head will cause electrical failure, Canon only advise 1 to 2 deep cleans over a 24-hour period. !
Try to always let the printer do the cleaning, head removal is only for last resorts, and never try to print with cleaning carts installed, and if you remove the head you can’t see a clog if one is present.
To keep your printer running smoothly, there is only one thing you can do to help keep it that way, try squirting some cleaning flood (1 or 2 ml) onto the purge pads evert 3 to 4 months and this will keep the purge unit in good condition.
The less you mess with the printer the better it will work; your only job is to insure you follow the set procedure for refilling (No short cuts) and change all the carts when one become low. (Not empty)
P.S. And don’t try to outsmart any of these Pro Printers, they’ll win or die trying...
