- Jan 24, 2011
- Kmt. 0.
- MB5150, Pro10s,,Voron2.4
I purchased recently a secondhand Pro9000 in great shape, including the printhead. Not a single nozzle missing in the extended test.
After being working some weeks with no issues, yesterday I noticed an almost sudden disappearance of yellow color in the prints. As the ink status for yellow showed full, I feared flow problems but when I removed the cartridge it was totally empty. Even the sponge, specially the upper part, was quite discolored meaning that it has been sucked dry. Apart from the printer status showing 'full', the led on the cartridge itself was steady red. No flashing at all.
Smelling a rat, I checked visually all the other colors. G,C,M,PB,PC and PM showed less than full in the driver status and all had still a noticeable amount of liquid inside, so it seems they're fine, but the red cart was like the yellow : totally depleted while the status in the driver was 'full' and the led in the cart was lighting steadily.
So I have now two colors -Red and Yellow- where apparently the ink status is not working anymore. I wonder where can be the fault. The chips, the printhead, the printer ?. Of course, if the new Yellow and Red carts work normally the fault must be in the chips of the older units but if they behave like the other two, then the problem must be in the printer or the printhead. For the record, these troublesome carts are original Canon and have been refilled/resetted several times ( the chips are also original).
Any clues, folks ? .. It's not rare that a chip fails, but then the driver and the led of the carts warns of a faulty condition. My issue seems to be the other way around.
