A
AmaDeuSbg
replied to the thread
Brand new CANON TM-255 OEM inks - ink scratches really easy from glossy media
@oliver666 This is sad to hear but at least good to know I do not imagine this. Did you find any other solution other than using...
Oct 14, 2025
O
oliver666
Pixma ip7250 strange error after replacement of print head and mother board
If the power and resume LEDs flash alternately, it usually means a board-head pairing issue. The new logic board and print head need to...
Oct 14, 2025
O
oliver666
How many of us are still refilling ink cartridges?
It depends a lot on the print volume. For those who print occasionally, refilling still makes sense. I switched entirely to compatible...
Oct 14, 2025
O
oliver666
Anyone using the PRO-310?
I have the PRO-310 and it's easily the most consistent pigment printer I've used. Nozzle switching works as advertised, and the Chroma...
Oct 14, 2025
O
oliver666
Python GUI to generate TI1 files for ArgyllCMS and convert to i1profiler patch set
Really cool project. ArgyllCMS is super powerful but not exactly user friendly, so having a GUI bridge to i1profiler sounds perfect.
Oct 14, 2025
O
oliver666
Had the same issue when testing glossy RC papers on Canon pigment models. The coating is not optimized for Canon Lucia inks. Try a true...
Oct 14, 2025
A
AmaDeuSbg
Thank you @thebestcpu , I also saw the office1 but since I did not see the exact same paper in my plotter page I passed it by...
Oct 14, 2025
A
reacted to
Ink stained Fingers's post
in the thread
with
Like
Give hairspray a try - as a test - just use the regular one not the strong stuff which is weatherresistant etc. You should test various...
Oct 14, 2025
A
reacted to
palombian's post
in the thread
Four flashing lights issue on Pro 100
with
Like
You might have to clean (gently) the contacts in the printhead too (with a cotton swab and alcohol).
Oct 14, 2025
reacted to
crenedecotret's post
in the thread
with
Like
This new version allows choosing the number of white and black patches. By default, a TI1's grayscale patches are always separate from...
Oct 14, 2025
Thoughts on OrcaSlicer for 3D Printing?
Don't think Option 1 well ever happen, probably not even on their future feature list. Option 2 is your best bet :)
Oct 14, 2025
C
crenedecotret
Oct 14, 2025
Oct 13, 2025
reacted to
Artur5's post
in the thread
with
Like
If the printer flashes in orange 4 times then it's a problem with the chip cartridge(s), not being recognized, either because there's no...
Oct 13, 2025
reacted to
The Hat's post
in the thread
with
Like
I didn’t mention anything about buying OEM carts, that’s was a Canon recommendation, the purge unit is where the print head sits when...
Oct 13, 2025
