reacted to
Ahftrea's post
in the thread
Thoughts on OrcaSlicer for 3D Printing?
with
Like
Since USB printing on Orca seems to be the main sticking point, have any of you found a good workaround for non-WiFi printers (like...
Oct 13, 2025
T
thebestcpu
replied to the thread
Brand new CANON TM-255 OEM inks - ink scratches really easy from glossy media
I am not in the EU yet take a look at this web address for Canon Glossy paper 20 sheets that can be delivered express...
Oct 13, 2025
C
crenedecotret
Python GUI to generate TI1 files for ArgyllCMS and convert to i1profiler patch set
That's normal. The displayed command at the bottom is just a preview of the targen command because I had some doubts while developing...
Oct 13, 2025
I tried to manually change the arguments, but it is overruled by the script. When I choose -B3 instead of the standard 4 it still...
Oct 13, 2025
C
crenedecotret
Thanks for looking at the tool. This is a first attempt I noticed the issue with the scramble button. I wasn't sure if i1Profiler was...
Oct 13, 2025
C
ConradH
reacted to
Epatcola's post
in the thread
with
Like
I had a quick look and saw 60 bytes sent for each button press. I expect those 60 bytes mostly contain 31 spectral measurements. I would...
Oct 13, 2025
C
ConradH
Yes, I need to try and connect the data to the individual spectrum measurements. Note that that entire series of transmissions and...
Oct 13, 2025
A
AmaDeuSbg
reacted to
thebestcpu's post
in the thread
with
Like
Hi @AmaDeuSbg There is no question that pigment ink has a larger propensity to sit on top of glossy papers, which can create issues...
Oct 13, 2025
A
AmaDeuSbg
reacted to
thebestcpu's post
in the thread
with
Like
I cannot speak to what to expect with the katana papers. It seems unusual to be that scratch sensitive and comparing to a Canon paper...
Oct 13, 2025
A
AmaDeuSbg
reacted to
Ink stained Fingers's post
in the thread
with
Like
Give hairspray a try - as a test - just use the regular one not the strong stuff which is weatherresistant etc. You should test various...
Oct 13, 2025
A
AmaDeuSbg
Thank you both @thebestcpu and @Ink stained Fingers I am located in Bulgaria and sadly all the cut papers I found (there were just 2-3...
Oct 13, 2025
I took some time to create a 702 patch target using 128 grey steps with the python script and below you can download the workflow for...
Oct 13, 2025
E
Epatcola
Oct 13, 2025
The strange behavior of i1Profiler in the amount of grey and near neutral patch generating If you choose 1589 patches: alot of grey...
Oct 13, 2025
One thing in your python script: the amount of black patches is not defined but standard set to 4 I see the command window the argument...
Oct 13, 2025
