costadinos
- Nov 16, 2012
- Location
- Cyprus
- 7900, 4900, 9890, R2000, P50
After filling with pigment ink and profiling an Epson 1400, I noticed that reds are now very weak, wherever in a print there is saturated red it turns into a brownish/orange solid area.
I used IS black and magenta, Light Cyan and Light Magenta from the IRK4-nano for the R2400 inkset and Yellow and Cyan from the OCP inkset I use with my R2000.
The print screen in Photoshop illustrates the problem perfectly, all those greyed areas (when "gamut warning" is enabled) print as dark brown instead of red.
And here's the gamut compared to what I get with the R2000 (the solid green line is the 1400):
Any ideas what's causing this? Red is made from magenta and yellow, so the problem should be one of those two colors, right?
Those of you using pigment ink in a 1400, what type of ink do you use with it K3/K2 equivalent or something else?
