- Thread starter
- #21
AlienSteve
- Mar 24, 2005
- Lacey, WA USA
- HP 3000CP Epson 1280 4800 7600
Hey, that's great! You went back further than I did. 2006 showed no images and seemed to go into less detail.
Careful about Windex! There are different kinds. I use steam distilled water, nonsudsing household ammonia, and isopropyl alcohol.
Scroll down to 6a for details on making it. This way you know exactly what is in it. Who knows what Windex puts in it this weak? And there are several varieties of Windex.
http://www.polyphoto.com/tutorials/PrintHeadCleaning/EpsonCleaning.html
I bought a device that clips onto the cartridge and provides a port for a syringe to inject and empty an HP 45 through the print nozzles. Make sure the outer surface is very clean, first. I do this upside down so any air gets sucked out. That seems to be the major cause of a "clogged" print head is that a little bit of air gets in every time it refills the print heads.
I did this to make sure there was no air left trapped in the cartridge. I did not try to completely fill it, letting the printer do that.
This person goes into a lot of detail on the anatomy of an HP45 cartridge. The only difference for us is the upper fill hole with spring loaded ball bearing. If you push this in, the cartridge will fill completely with air.
http://wandel.ca/hp45_anatomy/
