- Thread starter
- #11
Trigger 37
- Dec 23, 2006
Marine,... Plus all others that responded to this thread,... thanks a million for the information. All of it is and will be very helpful. In my first post I had mentioned that I had a problem with the some compatible ink carts but I had found the problem. I thought I would get automatic notification on all posts to this thread but that didn't happen. I just stumbled onto the answers today. The problem with the compatible ink carts was that I placed an order for two different types of Epson ink carts. After checking much closer, I found the shipping had mixed them up in the package so I was trying to put two different part numbers in the same print. Talk about LOL....
The refill instruction look very good. It seems this process would work on other Epson ink carts such as the T069xxx series. If it does that would be great. One set of toos to work for all those ink carts.
If mikling would comment on this??? Looking at your pictures it seems that if you use the fill hole that is right next to the exit hole, the fill ink would just flow right out of the exit port and not fill up the rest of the ink cart. There is no way to tell from the picture how the ink gets into all the other compartments????
