Found this "spongeless" cartridge on Ebay here in Oz. Bought a few to trial. They come prefilled and are the cheapest I have seen here in Oz. But as well it has other features that make it potentially quite versatile.
Comes with its own clip in case to seal the exit port.
It seems to have two chambers but does have sponge in the exit port.
There is an orange spike that seals the air hole while in transit.
The air hole seems to be in a tube that goes down into the chamber. The hole seems to be in its own well and does acumulate a few drops of ink.
The spike is removed in normal use.
It is advertised as refillable and has a silastic plug that is easily removable and so should be great for refilling.
It may even be useful as a CIS cartridge - by putting the orange spike back in and finding a spigot to go in the hole withe silastic plug to connect to tubing then theoretically this could be part of a CIS setup. Presumably the cartridge holds more ink with no substantial sponge?
Has anyone seen these cartridges elsewhere or tried them? I have just put a set in my IP3000. After a few prints the colours a bit off and on removal of the cartridges the print head wells are a little inky as seen with many non oem cartridges. The actual surface of the print head is a bit "wet" with ink but no smudges on the printing. I'll use the ink and then try refilling with formulabs ink.
