Roberto Smith
- Sep 24, 2017
- Canon
Okay this is probably going to be a fairly long post so bear with me (I'll to a tl,dr at the end
So as a side hobby / business I make custom stickers for Lego sets. I design them using Inkscape, export the images as .png and then import them into a package called Sure Cuts A Lot (SCAL for short). SCAL is used for laying out the stickers but most importantly is the key software connected to my vinyl cutting machine, so I can pre-cut the stickers. I can't just print from Inkscape as the SCAL software controls the cut lines and also has to print the registration marks, which are L-shaped guides in the top left, top right, bottom left and bottom right of the page. The vinyl cutter scans these so it know's where it's supposed to be cutting.
One issue I noticed is that it's hard to get the primary colours of the stickers to match the Lego bricks. Blue is particularly troublesome, then green, red maybe not so bad but not perfect. At first I thought the printer just couldn't print in a wide enough gamut but then I decided to have a custom ICC profile made. As part of the process the company making the profile sent me an app that forces the printer to create a large colour matrix - basically printing out its entire gamut (in steps) so they can use a machine to scan the colour matrix and make the ICC profile for the printer / paper combo I'm using.
On printing out the colour matrix, this is when I first noticed that the colours I'm looking for are actually achievable by the printer and the app. the company had sent me had actually got the printer to create the much more saturated blues, greens and reds I was after.
I then got the ICC profile but even with that controlling the colour, I still can't get the SCAL (vinyl cutting software) to create the colours I need. The problem is that it just doesn't have any colour management options so it just goes through the printer driver. Either that or it's just using the sRGB range so the gamut is pretty limited?
Again I was going to give up but I was tinkering around in Adobe Illustrator (free month long trial) and noticed that I can get much more saturated colours if I switch to the Adobe RGB colour space. On printing these out they were much closer to the blue, green and red colours on the actual Lego bricks.
Next step, I figured out I can export the to-be-printed sticker sheet from SCAL (vinyl cutting software) as a pdf file (including the all important registration marks needed by the vinyl cutter), import this into Illustrator and switch the colour space to Adobe RGB. Once printed on vinyl sticker paper, this then gives the colours I need. HOWEVER - I don't want to pay £25 a month for Illustrator just to print the occasional sticker sheet just to get better colours.
I only have the free version of Adobe reader and that also seems to have no way to select a different colour space to print with.
My question therefore is: I have a pdf file that I want to print in the Adobe RGB colour space - is there a way doing this without having to buy a subscription to a program such as Illustrator? Is there a way to print from Adobe reader? Is there a way to "force" my printer to print using Adobe RGB colour space?
tl,dr I want to force my Canon Pixma Pro to print more saturated colours and printing using Adobe RGB colour space seems to work, but I want a method that is free or cheap compared to a monthly subscription to an Adobe app that can do this e.g. Illustrator
