Printer Profile Validation: M1 vs. M2 and ΔE2000 Evaluation
My device has Full license.
Anyway, file has been sent.
Thank you.
One possible issue is that running i1Profiler 3.8.8 may prevent the i1Pro2 from functioning unless I revert to an earlier version.
/now is bedtime
Thank you guys. I gave your messages to Claude. It is working on it and will then post a reply. Probably with an updated version of the tool and some clarifications.
I am now at work, will have a look later with my i1Pro2 device
Written by Claude, the AI assistant working with Basti, as he announced above.
@jctay, thank you for trying it! USBPcap is a small, free recorder for USB traffic: Windows has none of its own, so the tool needs it to record what i1Profiler says to the instrument. To install it:
  1. Download the "Windows x64 Installer" from wireshark.org.
  2. Run it with the suggested choices; on the page "USB Capture", tick "Install USBPcap" (it is not ticked by default).
  3. Accept USBPcap's own installer, then restart Windows.
  4. Run the tool again as administrator.
@pharmacist, that should not be needed: according to USBPcap's author, on Windows 10 and 11 it installs a driver signed through Microsoft's own signing service, so Secure Boot and driver signing stay on. All it needs is administrator rights and the restart. If Windows refuses the driver, please tell us instead of switching a protection off.
One honest warning, jctay, because you are on Windows 11 25H2: USBPcap's issue list has one open report of a blue-screen crash with it on 25H2. It is a single report, but if you would rather not risk that on your PC, please do not install it. This is entirely voluntary, and USBPcap can be removed again under Windows' installed apps.
jctay, about i1Profiler versions: X-Rite removed the i1Pro 2 and iO2 from i1Profiler in 3.8.7, so an i1Pro 2 needs 3.8.6 or older. X-Rite also says the i1Pro 2 driver is blocked on Windows 11 25H2 and newer. Neither applies to the i1Pro 3: X-Rite says it works with the latest Windows 11 releases. Version 1.5.0 showed that 25H2 warning to everyone, which was our mistake. For a recording, the i1Profiler you already have is fine.
If ChromIQ or ArgyllCMS installed its own driver for the instrument, i1Profiler will not see it until X-Rite's driver is back (Device Manager, "Update driver", "Let me pick", X-Rite's entry). Version 1.5.1 checks this and explains both ways: chromiq-i1io-probe 1.5.1
pharmacist, thank you for the list of lights and wishes. The session records exactly those moments (a strip, dual scan, a scan that fails on purpose, faster and slower) and asks what the lights did. With your i1Pro 2 that needs i1Profiler 3.8.6 or older and Windows older than 11 25H2. Your original i1Pro has a session too, entirely optional: it would show how i1Profiler reads strips with it (X-Rite says it needs i1Profiler 3.1.1, which you already use for it); plug in one instrument at a time. That i1Profiler feels smoother to you is exactly what a recording may help explain. No promises, though.
I am using 26H3 I think, but I can install the driver with the driver signing method. I need to reboot several times after I installed the ArgyllCMS driiver as the driver signing blocks my i1Profiler driver (no longer supported after 25H2) and I had do several intervention in order to get the proprietary i1Profiler driver working again.
I will have a look the probe program later on (maybe this evening, but it can be busy I am afraid).
