Printer Profile Validation: M1 vs. M2 and ΔE2000 Evaluation
A small correction about the test
Sorry, I explained it badly: the test does not need a strip of 24 patches. A small turned chart of 4 strips with 6 patches each is enough. Print it, set i1Profiler to another grid (for example 5x5 or 12x2), and try to scan one printed strip of 6. If you find the time, that would tell us whether i1Profiler's strip mode lets a wrong grid through.
If I have interpreted your instructions correctly, the workflow would be as follows:
Step1. Prepare the Chart in ChromIQ
- Start with a CC24 chart using a 6 × 4 layout in ChromIQ.
- Set up the chart in the Beta tab, with Spacers set to None.
- Apply ChromIQ s turned algorithm and export the resulting .txf file.
Step 2. Generate and Print the Chart
- Change Spacers to Black & White or Coloured.
- Generate the chart.
- Print the chart using ChromIQ s Print Chart function.
Step 3. Import into i1Profiler
- Import the exported .txf file into i1Profiler.
- The chart should appear in a 4 × 6 layout in i1Profiler.
Step 4. Perform the Measurements in i1Profiler
For completeness, I 'll test the following three configurations:
1. Import the .txf file and retain the original 4 × 6 layout.
2. Import the .txf file and change the layout to 5 × 5.
3. Import the .txf file and change the layout to 12 × 2.
Each measurement should contain all 24 patches in the resulting .mxf file.
Important: i1Profiler must successfully measure and save all 24 patches. An incomplete measurement cannot be saved into an .mxf file.
Do you agree with the proposed workflow outlined above?
Note: I don't see any differences compared with the files I previously sent you.
I think I may not have made myself clear:
i1Profiler only allows an .mxf file to be saved after all 24 patches have been successfully measured. If even one patch is missing, the measurement cannot be saved as an .mxf file.
@jctay thank you, that was a good find, and your numbers made it easy to follow. Yes, there is a clear pattern, and it is all i1Profiler's own layout rule:
  • Columns: i1Profiler puts as many patches across as the paper width allows. It needs 31 mm of margin plus the patches, so with 8.5 mm patches 12 columns need 133.0 mm and 13 columns need 141.5 mm (31 + 13 x 8.5). That is exactly your 141.4 / 141.5 switch. It also cuts anything you type down to 0.1 mm, so 141.49 still counts as 141.4.
  • Rows and pages: the paper height must hold 35 mm plus the rows, rounded up to a whole millimetre: 171 mm for 16 rows, 163 mm for 15 rows. That is your 170.9 / 171.0 switch, and it is why rounding to whole numbers shows the pattern. The "Size: 13.3 x 17.1 cm" in the chart header is exactly that smallest page.
  • Rows 9 to 16 are not missing: when the rows do not fit, i1Profiler uses as few pages as it can and shares the rows out evenly, so 16 rows become 8 + 8. Your screenshot says "Page 1 of 2", and rows 9 to 16 are on page 2. A slightly smaller page that would hold 10 rows still gives 8 + 8.
Does this affect ChromIQ's charts? No. ChromIQ never sets the paper width on one of these switch points. For your chart the .txf asks for 137.25 mm, which is in the middle between 133.0 (12 columns) and 141.5 (13 columns), so there are more than 4 mm of room either way. The paper height is 210 mm, far more than the 171 mm needed. Your .txf files are not outdated: ChromIQ 4.3.30 writes exactly the same settings for your chart. We also checked about 28,000 other chart sizes, and none ends up close enough to a switch point for rounding to change the column count.
If the paper size is changed in i1Profiler and it ends up with 13 columns, the import of that measurement is refused with a message about the grid, so a wrong grid cannot slip into a profile. Spreading the same 12 columns over two pages is fine and is accepted.
One correction to an earlier post of mine: I wrote that i1Profiler chooses the rows first. It is really the other way round: it takes as many columns as the paper width allows, then the rows it needs, and then evens out the columns. For 24 patches on 2 rows that still gives 12 columns, so the example stays true.
Your test plan
Yes, that is the test, thank you for writing it out so carefully. Just two small changes, and a little background.
Two small changes
  • Please export the .txf after you have generated the chart with the spacers you will print (Black & White or Coloured), from that same chart. Then the file and the printed sheet are sure to belong together. Changing the spacers after the export changes the layout of the sheet, and the strips could end up different from what the .txf describes.
  • Configuration 1 (4 × 6 kept as it is) is the check that everything works. The interesting ones are 2 and 3, and there the most useful thing is not the saved file but what i1Profiler does at the moment you scan: when it shows rows of 5 (or 12) and you scan one printed strip of 6, does it accept the scan, refuse it, or ask you to scan again? A screenshot or the exact wording of any message would help a lot.
Why this is different from your earlier files
Your earlier files were measured once, on the right grid, and only saved again afterwards under other page layouts. i1Profiler then moved the finished readings to the new pages correctly, so they were all fine. This time the grid is wrong while you measure, so i1Profiler has to decide where the scanned patches go. That is the one case ChromIQ's grid check is meant for, and the one we cannot test ourselves without a printer and an instrument.
About the complete file
You were clear, and I understand: i1Profiler only saves an .mxf when all 24 patches have a reading. That is exactly what worries us. If i1Profiler accepts a strip of 6 into a row of 5, the file can still end up with 24 readings, complete and saveable, but with some readings on the wrong patches. So:
  • If i1Profiler refuses the scans in configurations 2 and 3, please tell us, that alone answers the question, and the risk is much smaller than we assumed.
  • If it accepts them and you can save all 24, please send us those .mxf files. We can then compare the readings with your 4 × 6 file and see straight away whether any reading sits on the wrong patch.
Thanks again for your time!
Your test plan
Two small changes
Well explained. Thank you for the clarification.
Work flow:
Each measurement should contain all 24 patches in the resulting .mxf file.""
Sorry, I just realized that Steps 2 and 3 in my workflow are obviously not feasible. I believe you understand why.
After I dropped a hint to ChatGPT:
"You're right. You cannot perform actual measurements in 5 × 5 or 12 × 2 layouts without corresponding physical printouts."
Gemin:
"If testing alternative grid layouts (like 12 × 2), you must generate a target layout natively built for 12 columns and 2 rows from the start, rather than trying to remap a 6 × 4 target post-export".
Claude:
"Why 5×5 and 12×2 fail: the layout is fixed once ChromIQ prints the chart. Changing the layout in i1Profiler only changes what i1Profiler expects to read. It doesn’t change the paper."
My main question is: Does ChromIQ provide a way to compare two sets of spectral measurements to evaluate measurement repeatability and consistency?
Hi @jctay ,
I imagine that several of the metrics that are calculated from measurements of a verification run when using the Measurement Report tool could be used as measures for repeatability and consistency.
One could ask claude which of the metrics would qualify best for this purpose.
All the metrics used are found under
Preferences --> Reports tab --> "Report Limits..." button:
Specifically, you have the two metrics under the heading "Repeatability, Measured by ChromIQ":
The first one "Maximum dE00, repeat patches on on sheet" does look at patches that are the same on a verification chart measured. The help info also gives a description of what you can do to measure this, i.e. to make sure the test chart measured have repeat patches of the same color:
However, I believe the other average and maximum metrics below also give an indicator of accuracy and repeatability, although these are across all patches of a chart measured, but still give valuable information:
Is this what you were looking for? or did you have another idea?
Cheers,
Knut
Hi @jctay ,
Cheers,
Knut
Thank you.
Measurement Repeatability Assessment
Just throwing my two cents in.
Several names have been proposed, such as:
- Replicate measurement check
- Scan-to-scan repeatability check
Claude offers a straightforward, practical approach that aligns perfectly with what I had in mind.
- Export both color sets as CGATS files.
- Calculate the ΔE00 color difference for each patch between Set A and Set B.
- Use BabelColor PatchTool by selecting its Compare function to perform the analysis.
Flag the outliers
- A fixed threshold, e.g. ΔE00 > 1.0 for a scanned i1Pro chart.
- If your paper and instrument are very consistent, you can tighten it to about 0.5.
Decide which set is wrong
Two sets only tell you where they disagree, not which one is correct. Take a third reading of the flagged patches and keep the two that agree. Or, for a smooth ramp, judge which value fits its neighbours.
Back
