Printer Profile Validation: M1 vs. M2 and ΔE2000 Evaluation
Here are my 2 examples for @itsab1989 and AI Claude to determine the coordinates of the pwxf file based on the pxf-file. We can convert from ti1 to pxf and vice versa. The pwxf-file is compatible to the ti2-file and the mxf-file with ti3
the first example is for a target on 13x18 cm photo card with 702 patches:
You can see the settings of the patch layout: 8x8 mm. 8 mm height is the minimum for i1Pro2 and thus also the same layout for the i1Pro3, with a minimum of 7 mm so we choose the common value of 8.
This target is spread over 3 pages
The next one is a virtual 648 target on a single sheet of A4 with the following setting:
This has a patch layout of 8.9x8 mm. I could have chosen 8.4x8 mm too without any problems: the row length is a bit shorter but stil with the 24 rows x 27 patches configuration:
However when I make a 0.1 smaller the amount of patches per row increases to 28:
It is now: 23 rows with 28 patches and 20 dummy patches (no data).
Below the 2 sets (pxf-pwxf combo's) for Sebastian to look at with Claude to see if there it is possible to convert a ChromIQ generated target with it;s ti1 and ti2 data towards a pxf + pwxf file so the exact coordinates corresponds together as a set.
ChromIQ 4.3.18 is out, and with it an updated step-by-step guide for measuring a printed ChromIQ sheet in i1Profiler as well. It replaces my earlier guide for 4.3.17: the most important change is that you now turn the sheet the other way.
@jctay, your idea started all of this, and @pharmacist, thank you for testing it so quickly: you found the spacers problem and reported that 7 mm patches read fine with an i1Pro 2. Both are fixed or included in 4.3.18.
What changed since the first guide
  • Turn the sheet a quarter turn CLOCKWISE, not anticlockwise. The wide clip border (the margin on the left of the upright sheet, where the ChromIQ logo is printed) is then at the top, where the clip of the ruler's backing board holds the paper. Strip A is the top row, and the strip labels are on the right. If you set the clip border to the right in Create Chart, you turn the sheet anticlockwise instead, so that the border is at the top too. Charts made with 4.3.17 keep working: turn those sheets the way their own note says.
  • Any paper size can qualify now, portrait or landscape, with any number of patches per strip. The patches must be 7 to 25 mm long along the strip, for the i1Pro 2 and the i1Pro 3 alike. The rest stays as before: every strip full, no spacers, and the whole chart must fit on one i1Profiler page, which is at most 1270 mm tall (about 150 strips of 8 mm). A4, Letter, A4 landscape, 4 x 6 inch and 5 x 7 inch were compared cell by cell with i1Profiler 3.8.8's own chart, using the i1Pro 3 file. On every chart, and especially on small paper, check the grid i1Profiler shows (step 9 below).
  • No more false refusal for "Edge spacers". In 4.3.17 a chart with Spacers set to None got no i1Profiler file when the box "Edge spacers (bracket each strip)" was still ticked, although that box prints nothing on such a chart. That was pharmacist's case (504 patches, 8 x 10 mm). 4.3.18 looks at the sheet itself, so such a chart now gets its files.
  • The i1Pro 2 file is now written from 7 mm patches, like the i1Pro 3 file (4.3.17 wrote it only from 10 mm). To be honest about it: the i1Pro 2 file has still not been opened in i1Profiler, because i1Profiler on our test Mac offers no i1Pro 2 option. It follows the same rules as the i1Pro 3 file, but it is unchecked there.
  • "Prioritise chart area" charts: on A4 and Letter portrait they qualify too, as long as they have no spacers and full strips (for example 24 strips of 27 patches on A4). On taller paper their strips are longer than one i1Profiler row can hold, and the note says so and tells you to use "Prioritise patch size, then fit to page" instead.
Before you start, please keep in mind:
  • It is a beta option, off unless you switch it on.
  • It works only for the i1Pro 2 and the i1Pro 3, read by hand along the ruler, and only for RGB charts without spacers. Not for the original i1Pro, the i1Pro 3 Plus, the ColorMunki, the i1iO, the i1iSis or any other instrument.
  • The layout was checked patch for patch in i1Profiler 3.8.8 with the i1Pro 3 file: for the chart in this guide, i1Profiler's chart and the turned ChromIQ sheet have all 504 of 504 patches in the same place. Nobody has measured a real sheet yet, because I have no i1Pro 2 or i1Pro 3.
  • The import pictures at the end use a test file, not a real measurement.
1. Update to ChromIQ 4.3.18
Download it here: https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.18
2. Switch the option on
Open Preferences (the Preferences button at the top right, or ⌘, on a Mac and Ctrl+, on Windows), go to the Beta tab and tick "Also write an i1Profiler chart that matches the printed ChromIQ sheet (i1Pro 2 and i1Pro 3, beta)". Press OK. (If you switched it on in 4.3.17, it is still on.)
The ⓘ button next to it explains everything in detail. First what the option is for, and which way to turn the sheet:
Which instruments and which charts, and what happens to charts made with 4.3.17:
Where the files go, and how the measurement comes back into ChromIQ:
Measurements without device values, the beta warning, and the default:
3. Which charts qualify
ChromIQ writes the i1Profiler files only for a chart that i1Profiler can lay out exactly like the printed sheet:
  • an RGB chart made with "Use the ChromIQ layout engine instead of printtarg", for the instrument i1Pro / i1Pro 2 / i1Pro 3;
  • Spacers: None, and every strip full;
  • patches 7 to 25 mm long along the strip (for the i1Pro 2 and the i1Pro 3 alike), on any paper size, portrait or landscape;
  • strips at most 241.5 mm long (ChromIQ's own strips end at 240 mm unless you set a longer strip length limit);
  • small enough for one i1Profiler page, which is at most 1270 mm tall: about 150 strips when they are 8 mm wide, about 100 when they are 12 mm wide.
If a chart does not qualify, ChromIQ writes only the note, which says why, with the real numbers, plus one line in the Create Chart log.
4. Make the chart
On 1. Create Chart, choose MANUAL. This is the chart I used, and it qualifies for both the i1Pro 2 and the i1Pro 3:
  • Use the ChromIQ layout engine instead of printtarg: ticked
  • Instrument: i1Pro / i1Pro 2 / i1Pro 3
  • Paper: A4 (210 × 297 mm) Portrait, Pages: 1
  • Create layout: Prioritise patch size, then fit to page
  • Patch size (mm): 8.0 × 10.0 (8 mm across the strip, 10 mm along it)
  • the patch count left on Auto, so the page is filled with full strips
Then open Expert Options and set Spacers: None:
Press GENERATE CHART. You get one A4 sheet with 504 patches: 21 strips of 24 patches, 8.04 × 9.99 mm on screen, no spacers, and the margin check says Margins: OK.
5. Where the files are
The Create Chart log shows the new files being written:
They are in the run's exports folder (for example ~/ChromIQ/<project name>/runs/run1/exports/):
  • <name>-i1profiler-turned-i1Pro2.txf: the i1Profiler test chart for the i1Pro 2
  • <name>-i1profiler-turned-i1Pro3.txf: the same for the i1Pro 3
  • <name>-i1profiler-turned.json: the order file ChromIQ needs to bring the measurement back. Please do not edit or move it.
  • <name>-i1profiler-turned-how-to.txt: a note with every step for exactly this chart, including which way to turn the sheet and the grid i1Profiler must show
Here is the note for this chart (opened in a plain text window). The beta warning, the instruments and steps 1 to 5; step 2 says CLOCKWISE, and step 5 names the grid, 24 columns, 21 rows, 1 page, patch width 10.00 mm:
Steps 6 to 8, and which i1Profiler row is which ChromIQ strip (row 1 is strip A):
The File Guide lists the files too (the ? button at the top right, then Where are my files? (folder guide)):
6. Print from ChromIQ as usual
Print the chart on 2. Print Chart, exactly as you always do. Do not print i1Profiler's chart: the whole point is to measure ChromIQ's sheet.
7. Turn the sheet a quarter turn CLOCKWISE
Turn the printed sheet a quarter turn clockwise, so that the clip border (the wide margin on the left of the upright sheet, where the ChromIQ logo is printed) is at the top, where the clip of the ruler's backing board holds the paper. The strip labels are now on the right, and strip A is the top row. Every ChromIQ strip is now one i1Profiler row, read from left to right (that is from the strip's last patch to its first, which is fine: the files are written for exactly this).
Only if you set the clip border to the right in Create Chart: turn that sheet anticlockwise instead (strip A is then the bottom row). And a sheet printed from a 4.3.17 chart: turn it the way its own note says. When in doubt, step 2 of the note for your chart is always right.
8. Load the .txf in i1Profiler
On i1Profiler's start page, set User Mode to Advanced, and under Application Settings set Default display device to the family of the instrument you measure with (the i1Pro 2 family for an i1Pro 2, the i1Pro 3 family for an i1Pro 3). This matters: with the other family, i1Profiler reads the patch size on the wrong scale and the rows come out wrong. Then choose Printer, Profiling.
Press Next on the Patch Set page. On the Test Chart page, under Page Data, press Load and choose the .txf for your instrument. When i1Profiler asks "Would you like to copy this file to the assets folder?", either answer is fine. If you still have a 4.3.17 file for this chart loaded, load the new one: the files of 4.3.18 are written for the clockwise turn.
9. Check the grid
i1Profiler must now show exactly the grid the note names. For this chart the note says: 24 columns, 21 rows, 1 page (Page 1 of 1), patch width 10.00 mm. If it shows anything else, stop: the rows would not match the sheet. Please do this check on every chart, and especially on small paper such as 4 x 6 or 5 x 7 inch.
(This is i1Profiler's own chart for the i1Pro 3 file of this very chart, saved with its "Save as..." button. Row 1 is strip A, and all 504 cells match the turned sheet. i1Profiler names its patches by its own columns and rows, A to X and 1 to 21, so its "A1" is not ChromIQ's A1. That is expected.)
10. Measure
Press Next to the Measurement page and choose a measurement mode:
  • i1Pro 2: Single Scan (M0), or Dual scan (M0,M1,M2 and OBC) if you want M1 and M2 as well (each row is then read twice, forwards and back);
  • i1Pro 3: Single scan (M0,M1,M2 and OBC), which gives M0, M1 and M2 in one pass.
Calibrate, and measure the rows from top to bottom, each one from left to right, starting and ending on the white paper beside the row. i1Profiler checks every row against the colours it expects and asks you to read it again if it does not fit. Please always do that: it is the check that catches a row read in the wrong place, and ChromIQ cannot see a misplaced row afterwards. Leave i1Profiler's Scramble patches setting off, and measure the whole chart.
11. Save the measurement
When every row is measured, press Save under Page Data on the Measurement page and save it as an .mxf file (the format this was checked with). A CGATS text export that includes the RGB values works the same way. One without device values is refused for this chart, because only the RGB values tell ChromIQ which patch each reading belongs to.
12. Import in ChromIQ
Open the run, go to 3. Measure, press IMPORT, choose the file with the folder button beside Measurement File (from i1Profiler), and press IMPORT MEASUREMENT. ChromIQ checks that the device values in the file are this chart's, entry for entry, and then puts every reading on its own patch. A file that does not match, or holds only part of the rows, is refused and nothing is changed. If the file holds more than one measurement condition, ChromIQ uses M2, then M1, then M0.
The next three pictures use a test file, not a real measurement: it was generated from this chart's i1Pro 3 .txf the way ChromIQ's own tests build one.
The log line to look for is "This is a measurement of the turned i1Profiler chart, so ChromIQ put every reading on its own patch of ... in the turned order":
After that you can build the profile on 4. Build Profile as usual.
Please tell me how it goes
This is still the part we could not test: a real sheet, a real i1Pro 2 or i1Pro 3, and a real i1Profiler export. If you try it, I would love to hear whether every row reads in i1Profiler, whether the grid matched the note (please tell me the paper size and patch size if it did not), whether the import goes through, and anything that was unclear. If someone with an i1Pro 2 can load the i1Pro 2 file in i1Profiler and check the grid, that would be especially helpful. Feedback is very welcome, good or bad.
