- Nov 3, 2004
- Location
- Bay Area CA
- CR-10, i560 ,MFC-7440N
Friends,
How about a thread regarding ideas on keeping our printers in tip top shape? Okay, here it is, and I'll start!
First off, dust is a know killer of inkjet (or any other type) printers. Where I live we get quite a bit of dust, but I print too often to keep one of those printer covers on my little workhorse. For the most part dust is heavier than air and settles of vertical surfaces. This being the case I see the top of my printer, especially where the paper is loaded, as a weak spot for dust collection. What I've done is taken a small pillow case and folded it in half a few times so it will lay right over the hole between my paper and the printer. This stops the majority of dust from getting into my printer. The only time it has been a "problem" is when the paper doesn't feed correctly and the printer rolls it forward and then back up where it rubs a bit against the pillow case. This is pretty rare.
Regarding dust... don't ever use a can of air to blow dust around in your printer. This usually pushes dust from non-damaging areas into places that will cause problems. If you must, you can get small vacuum attachments to suck the dust away.
Something else I've tried (but don't know if it helps) is to use a porous material (paper towel, q-tip, etc.) and try to wick up as much ink as possible from the pads that the printhead sits on. I'm hoping that this will stall the "waste tank full" error message indefinitely. I don't do this too often due to the difficulty of access and the lack of knowledge of how this effects the pads and printhead.
I've also just started leaving my printer on 24/7 based on comments received here: http://www.nifty-stuff.com/forum/viewtopic.php?id=141
Any other suggestions?
