- May 29, 2007
- Location
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
After refilling my EpsonP800 several times I discovered the LLB ink has a particular high usage that does not correspond at all with the ink level detection by the printer. The first time it caused air being forced into the tubing system (as the ink level still says about 40% full, but was completely dry physically), forcing me to reinitialise the printer to load the inks like the first time the cartridges are installed. So be careful and check ink level of the LLB on a regular base and refill if necessary accordingly. The other colours seem to correspond pretty well with the ink detection level on the printer panel.
