Hi Mike L
You don't give much information such as which software approach you are using for scanning as there are several ways to do scanning to the computer. Without more details, here is a more broadbrush approach answer for the several ways to go about scanning and what to do when it does not work. This is off the internet and I do not have that HP printer. I always initiate scans to my HP printer via the computer and not from the printer and have never had a problem.:
Here’s a step-by-step guide for scanning to a Windows 11 computer with
your HP OfficeJet 4650:
1. Make Sure Everything Is Set Up
- Connect printer: Ensure your HP 4650 is powered on and connected to
the computer (via USB cable or Wi-Fi).
- Install software: If you haven’t already, install HP Smart or the HP
Full Feature Software and Drivers:
- HP Smart for Windows 11 (Microsoft Store)
- HP Drivers and Downloads
2. Using HP Smart App (Recommended)
1. Open HP Smart on your PC.
2. If not added, click “+” to add your printer.
3. On the home screen, click Scan.
4. Place your document:
- Flatbed glass → face down, aligned to the corner.
- Document feeder (if using multiple pages) → face up.
5. Adjust settings (scan type, color, resolution, file type).
6. Click Scan.
7. When complete, click Save → choose JPEG, PDF, or TIFF → save to your
computer.
3. Using Windows Scan App (Alternative)
1. Download Windows Scan from the Microsoft Store (free).
2. Open the app → select your HP 4650.
3. Place the document on the scanner.
4. Choose File type (JPEG, PNG, PDF).
5. Click Scan.
6. File will be saved to your Pictures → Scans folder by default.
4. Using Windows Fax and Scan
1. Press Windows key → search Windows Fax and Scan → open.
2. Click New Scan (top left).
3. Select your HP 4650 as the scanner.
4. Choose settings (document type, color, resolution).
5. Click Preview if you want to check, then Scan.
6. Save the file from the preview window.
Tip: If scanning fails, restart both printer and PC, make sure
Windows detects the printer under Settings → Bluetooth & Devices →
Printers & Scanners, and reinstall HP Smart if needed.
